Gaeta Falcata (Gajeta Falkusa) by jack.aubrey - Marisstella - 1:20 Scale [COMPLETED BUILD]
Tuesday, March 28, 2017
A new small step forward: I have corrected a blunder that I discovered in the execution of the two floor decks at bow and stern. Now these two "decks" have the right length, 'cause before were too long, although on the plans there aren't the two small lateral extensions which unfortunately I could not totally eliminate.
I hope that the replica shipbuilders will forgive me. For me this detail introduces an aesthetically improved element [cursing] [cursing] [cursing]
Previously I installed, not without some difficulty, the two side counterwales. Unlike the stringer, the engravings on the counterwale are two. Now I became a master in its execution. When the boat will be completed with the so-called "falke", there will be three wales/counterwales per side, two outside of the hull, one inside.
Now it's time to study in deep the assembly instructions in cojunction with the plans to setup a proper planning for the next steps.
They are not so obvious . .
Salutoni, Jack.
y4mhjszw-Tc-o2sBs7hUvWBAOQk0vnKPhotNGgf0
y4mHKTA3fJSMz5p6RldB6sbArK5wci1CScvnzFCg
y4mk83UgI9Mb6pxhIwecuPrYsErsNMbU0BOMDcb9
y4mVvCGfIJFvQ52GMNV5Xz7z4cw5l6EKihnNcyaS
Thursday, March 30, 2017
More details, the job begins to get interesting and fun. Now I'm back for 4/5 days in Milan, I plan to return to Pisa next Tuesday. So do not expect news soon.
y4m34HcmjwTZJ2c6bqEQe5JPFwnF9FiCQlPCuwPH
y4my53eydRcTZAD97dDGHHL7yahP_zyLlE_5pFH0
y4mIMBPtV3M_Flw_0tcVIlgt98L_zU_8CsYLLRQN
y4m_eiFL-8-a9db2XNl9_YHqoo9-LqowD4h5U2iq
y4mmYIg9ex7Gfb_PAoYhXtqOkh0TPRGnPzqkwPPM
y4mIw9pjNdAlBKSF7b1mZ-jR140GuADpbBx7F91G
Tuesday, April 11, 2017
The work is progressing well, not at high speed, but it goes well and I'm having fun.
Today I finished the two decks at bow and stern and then I better refined the gunwale. I'm glad I guessed the suitable wood for decks. When I was back to Cinisello I did a little research in my personal timber store and found these light walnut strips that make a good contrast with the color of the other boat elements. Those supplied by the kit seemed me too dark for these task.
y4mgqQe_wsZBFI8Mqq23b1-kyvOmikgfBfIG_9yu
y4mvZvKUOEHp-dDqOcxOB0gXHrWhuX44-LFMs8CM
y4m3BZwgb8HF3ZVnRs3CdEwE1G0p3ICukBmYgexE
y4mRvASIcTFymvsnRsPCPaAZH8ApnNrdI5PING9h
y4mbeBnbPqjpMPm1HEOOLOznS-Qvx1mF5IYaGgDa
y4mrLmt6XIOzMOeppsrj1EHH6IorJ1kAurjiBB79
Now I must understand what are the next steps, so I have to study the plans/instructions to decide the correct sequence for installing the other details. However, the date of my return to Cinisello approaches and I definitely will not be able to finish this model in time. I must then decide whether to let him in Pisa waiting to complete it on my return next fall or bring it with me in Cinisello and finish it there, similarly as I did with the Viking ship model.
Should I decide for the latter, of course the other model (Brick de 24) I have in the shipyard at home would still remain idle.
Sincerely yours, Jack.
Thursday and Friday, April 13-14, 2017
At the end I decided to install the seats . . .
There were some difficulties to solve, so I decided to do a test with some unused material. The first difficulty was to bend the strip which constitutes the seat, giving it a humpbacked curvature that was stable and, above all, reproducible in four equal pieces. At the end I opted for bonding two strips held to dry in a jig having a proper shape which gives it, once the glue is dried, an right curve.
Then I had to solve the problem of how to insert the seat in the right place. The following photo shows the solution I found.
y4m19xDQXx_Of12qCfJae8T-LQ5FPC8O4XNWvkVs
Picture 02 shows the method I used to obtain the required shape for the seat.
y4mCp_NfD6H8xyxozlVDyvMTF7Yurftfe4GwqM3H
The remaining images show the final result. I think it's a good achievement . .
y4m-1MEHHHt_VoJvzW-STR7X8_Ksd2x5g__q-b5U
y4ms4J-uw2f4tBQyXI8mWRiCwrasZeYE1rJlV-Cz
y4mInxwm3ZPVQvo8FPvp1QAD2h04yowqIs4pclgY
More significant images will follow soon. Salutoni, Jack.
Monday and Tuesday, April 17/18 2017
It 's time to get myself dirty with brushes and colors . .
More precisely I painted with a matt acrylic white part of the gunwales.
For the first time I experienced the suggestion I received sometime ago from a friend modeler (expert in plastic modelling) that explained me the trick to prevent paint managing to sneak under the masking tape. The trick is to apply a coat of transparent (and matt in this case) paint on the border area between the masking tape and the part to be painted before using the final color paint. This clear paint seals the microscopic cracks that inevitably form . . It works great, thank you rudy.
y4mFE6C5k99zjIN1XQhesr7qbVITX-tuXnLMEaSq
y4movNMBFYSfvx9tKB8tsZ33iY4tZl3NpJcG1Ovy
I have also painted two wood strips in white: these are the wales to be applied immediately below the gunwale. My only problem: I do not know why but the acrylic white covering was poor and I had to apply many coats before obtaining a proper color. Luckily with the hairdryer trick I did not have to wait the paint getting dry between coats.
y4mO6JKWcmNJ2Nw7pxhFI8E6wa7kiEBMhg1PUzRf
Finally I proceeded to color with black acrylic the outer part of the hull, leaving for the moment unpainted the part where the wales will be installed, still to be completed and glued. I will do this task in the coming days.
y4m1rb78g4nf-MUbtoTDFQpJ0AzIKRZ5T4GA8Cls
y4mU67dJHepU-uP2Y4RsVjWxIhC9KzmoUvip3glf
Greetings, Jack.
Wednesday 19 April 2017
I installed the wales on top of the hull, just below the gunwales. Then I had to do some minor adjustments to cover the small damages caused during the gluing of these strips and, finally, a coat of matt transparent paint, or rather, slightly satin.
The real boat is completely polished black, but in a model I think a polished finish is not much suitable, so I opted for a compromise: a satin matt finish.
y4m1lZwHm8K_fODjwD6FzlqRusMV_UIiE94EaFRe
y4mEYyDZ_ui9A-DH9pLBMk7cEfqXW8U9FmPul1Br
y4m9PL5P-vmlZr9s1y55cko0YMJN06WJMEwtEYN1
y4mjF2BRHUNUQLkBXyTVJKj75aqdBUkHWRJ1tuqe
y4mUzq1WdhkzMWnD7XDwahK_ji5Yoi-A87jFm3Ms
y4mlu4rMmFxEq1OpGwwIG0D1Q3koWmkVYPwMjE6Z
y4mQxKPTzZ82IEQuf90A1yL19GZPbzkEK6OQm52p
Regards, Jack.
Thursday 20 April 2017
My stay in Tuscany is now approaching the end: next week I will be to the island of Elba for a short vacation that will allow me to see the island in the spring; people say it's very beautiful. Then again another 15 days and then I will return to Cinisello.
The next important step for completing this model is the construction of the so-called "falke" (I think it is translated in frisate), but for me this is an activity that is still to be understood, so I prefer to delay it when I'll resume work on this model.
So now I'm carrying on small "integrative" activities like the one described below with images. These are tables that are positioned fairly freely, between seats and having different functions . .
y4mKrTwDpjOd_63h-tzxGxED2_c9RDI1XybLoLyU
y4mjWpYXiOPFuKy0bc1svw4cXPGIOMr-Io7pZgvn
Surely an important function is to serve as a table for the food, which is necessary to bring on board as these boats were in the sea from early morning to late evening . .
y4miMBwKS49w8h55dLCPEOVbszQ1IKLsyOF2TIsb
Another usage was to make life a little more comfortable on board, adding more seats . .
y4m0Z_ZlELHFISIANVk2ytcC2g_G9dSAaZOcS0Ar
But, I think, the main function is to allow rowers to do their job, the picture below shows how the rowers work and we can understand that these boards put them in the most suitable position for rowing effectively . .
y4mAccArsAPnyngxpLk4bM_cJJ09rgc-DAtcSwZg
These are details not provided in the kit, but can be seen in the photographs of the real boats, so why omit them ?
y4mFuPG3B4q2pxuK7BoWU-4NMWTYVg1xWppKzpSc
y4miHiC-7p8qFRNJYmZ1Eizdm4tWr7L93Oz93PiP
To next time, Jack.
Saturday, June 24, 2017
It's since April 20th that this log isn't updated anymore. The reason is relatively easy to explain: in this period of time I went back to Milan from Tuscany and, as often happens after long absences from home, I found myself to be involved in everything and more. So nothing or very little modelling, save a timid resumption of activity over the past ten days.
Now my ultimate goal is to build the second part of the boat sides, the famous elements that could be removed after sailing and reassembled after fishing. The so-called "Falke". I do not think it will be an easy task, so I'm moving very carefully.
I started preparing the removable extensions on the bow and stern. I think the next four images can explain by themselves: these extensions are fixed to the protruding part of the keel and clutched on two metal pins holding this accessory firmly fixed. .
y4m-F-nk_palbpCnIzR4Bmsmc0TCwrPWjzRWYK_a
y4mrfDMr3zTFQ5P3qN-OBbBW0JcitwyPOrNCefB-
y4mUGmae9AYA9WCVgxcmxcX0YCiL4lYigabjTs_C
y4mpwz8-MFRqhJZq4FPIhSZ-JMu7FsE36388lYbO
By the way I built the rudder, though it will be needed a lot further. Below is a photo of this item.
y4moIOq10am86ErSekzIx4qNNSOZOwmncJCtRiW3
And here's the most demanding part: the picture below shows all the bulwark stanchions on which the "Falke" planking will be applied. Here are presented after the long treatment received. The pieces were laser precut and obviously, on the cutted side, they were all black and burnt. The first activity was to remove the burns to get the original color of the wood.
Afterwards I had to work to fit the openings of the gunwale, where to plugin every single stanchion, a rather delicate and boring task: 24 square holes to fit.
Finally, when everything was fine, I could stain all the stanchions with a medium wood color. Now they are drying and finally the next job can start, provided the necessary checks to assure everything is properly set up.
y4mBFTXoxakOfyn5OnDtEc-HML7XAlCJlR3LFvhe
Hopefully, I hope not have to wait two other months to post the next message. Cheers, Jack.
Wednesday 28 June 2017
I put the items shown in my last message of June 24
(and displayed into its last image) in their proper locations so that, once the glue will be well dryed, I'll can start to install planks over these new hull elements.
I thought for a long time to find a method of building these "falke" in order to allow them to be removable, instead of leaving them permanently held but, although I had some idea, I didn't feel confident to try it. There were too many unknown things, one for all: did these so assembled falke maintain their correct shape once extracted from their beds ?
So, though with a little reluctance and remorse for my defeat, I decided to fix them. In the photos here below I show all the bulwark stanchions in their room, obviously well glued, indeed rather than well.
y4mOFjOQTmuAcoS4lyxUdrCKQgC89R5NkDf3lbhQ
y4mDQ6Pf4hKzoKHnR0O2v0H02VQvvCbM0zXYTldx
y4mMmMRCjzQFLOcyXUvJ1GT0szPY0OYQk10WNsFt
y4mFBnxuu9MQg32WoNGwqoL-t-B4iP91dtNQc6ua
y4mfx3G20A8beMpj3LNbHdtMeMp83R9wsliRAhuk
y4m6uTA71QwnJhUO02Me21MnGhKDC4uIYRy21OMP
y4mSigxnRkCmMH8g3Ag7XvPsutbePUZTyKiOQWo2
Cheers, Jack.
Tuesday, July 4, 2017
I am now building, even if not removable, the so-called "falke". We are still far from completing them, but we already have an idea of how the hull completely changes . . From a boat low on the water we are now facing a high-sided boat, much more suitable for sailing.
Enjoy these images. These should be forever . .
y4mz_ialvnOQXRjv6rp0ykCCn7jedhA8nc7K7F-v
y4mIPzKQJfeRuDYUkOrgeP4c2PkxHfXW8YsdVnOC
y4mvwN0S-JqK5HHppXcWPyyG3IhHWTQyLSdvpzg2
y4mcObP8E_ZD56l7ZGpUtTtnz97unulKU7ZCoxhc
y4mP6AsRA4sdxfDserH5fulN98LvUO-WxznQHheR
Regards, Jack.
Saturday, July 8, 2017
Completed the planking of the top sides on the hull, in particular I raised, as planned, the height of the sides in the stern and, above all, in the bow area.
Now I've to start the cleaning and refining tasks before proceeding with new details of these "falke".
y4mpL1lHKAulzkzNGFfCLddKYzxlz73n-pJLgYpA
y4muzbZku8gBPM-WpquBKq8xIoJ6_72lff_F43_m
y4meDWIxAgwfXQv17KFZ5Pogjm9fV3xnGamF_j2K
y4mVhakwekYDhEpwmCHHLkE91oT0jyHZZVsTRysA
y4mRHwC6GHkp6rxSJd48lZhrxPgoysfsHttblRo-
See you soon, Jack.
Saturday, July 15th, 2017
The hull practically finished. Now, only minor details are missing, and a final black paint coat on the outside.
Next planned activity: building the oars. My starting point is a nice walnut stick 7 x 7 mm. I'm thinking about the right procedure to make them.
Regards, Jack.
y4mgFI7cc8R1hA9pyf_l_otZjc9XhM80owwrP0PX
y4mV4wFxbkAlL737OTpIx9_DAgap-8-5B0EKaT_B
y4mEDoqyxXTzHysvy8TrVH59b-zgloEJP2osn4UJ
y4mA73ZKd9wvUcwuxg7hSyTEpYJJNNpv5ohNsRNi
y4m7y5JtP2tQKk3Ys0Uos-ivKE0zh6dOM9TQP1uD
y4mJrcASqIbuI5tXBWZeLoIgOx6VnWY88-qgh8vg
Wednesday 19 July 2017
Completed, with the latest details, the hull, inside.
y4mP1nkrDoFjQAiZK9mSmOdW1raCHL8ZoICldulM
y4mUvygH5DHILQhGwZU3HqhmV9mwqzMhMjoHqWNZ
y4mUgqQy2M0fthf9os_v3E0FVFYSnRfde2Mgb1O5
Friday, July 21, 2017
Built the oars on Thursday, today I did some color 'cause all clear walnut was a bit too serious !!
y4mfbDLRqw5fyUAbiJ-9rP6_iSHfh2HaYQDmQT2v
y4mWEMEadpRZU521zYO9lBYfyF_pgcbBKZfU07_8
y4mv77fHjC3uEBjzEvbFm02j-HJo4h-8mkvCPoH0
Regards, Jack.
