- Mar 19, 2021
Good morning. Looking fantastic. I do like the look and feel (real pirate ship). Cheers GrantAll 16 guns mounted and secured on this side. Also finished cannon port doors. Just need to add hinges and do some painting.
Thank you sir!Good morning. Looking fantastic. I do like the look and feel (real pirate ship). Cheers Grant
Damn, you’re right!! Rookie mistake. Those things took a while to build. Might be easier to cut the anchor and glue it back together. Haha!! Yes the black swoops were one of the more frustrating and fiddle parts of the kit. I’m afraid I didn’t do them too much justice.I found the black swoops on the bow to be very fiddly on my BP. Are the stocks on the anchor upside down?
If you're going to cut them apart then go ahead and turn the anchor stock 90 degrees...should be perpendicular to the anchor 'flukes'. That's a nice looking ship you're building!Damn, you’re right!! Rookie mistake. Those things took a while to build. Might be easier to cut the anchor and glue it back together. Haha!! Yes the black swoops were one of the more frustrating and fiddle parts of the kit. I’m afraid I didn’t do them too much justice.
Already turned them 90 degrees after I looked up a few on the internet. I actually did a bit of research before building them but I guess I didn’t even think about the angles. Oh well, live and learn. Thanks for the compliment.If you're going to cut them apart then go ahead and turn the anchor stock 90 degrees...should be perpendicular to the anchor 'flukes'. That's a nice looking ship you're building!
I had a horrible time with the swoops. They kept breaking on me. You do have a nice looking BP. Very clean.Damn, you’re right!! Rookie mistake. Those things took a while to build. Might be easier to cut the anchor and glue it back together. Haha!! Yes the black swoops were one of the more frustrating and fiddle parts of the kit. I’m afraid I didn’t do them too much justice.
I broke them several times as well!I had a horrible time with the swoops. They kept breaking on me. You do have a nice looking BP. Very clean.
Yeah I thought about trying to stain some of the areas that show white but I haven’t came up with a fool proof plan as of yet. Since the walnut is sealed, I could probably use a qtip and push some stain into the cracks and then give it a quick wipe. Might try that on an inconspicuous area.Very nice. For future reference, you could paint the first planking of the hull with dark paint, especially if you’re using darker wood for the second planking. The white of the under planks will show through any cracks of the outer planks. I absolutely love your lights and your stand.
It’s probably too late on this model. As you get more experience, the cracks get smaller and you learn how to compensate. On my Soleil Royal, I used a thin coat of putty to simulate caulking and sanded it all off except for the joints between planks. It was a wet putty from a tube.Yeah I thought about trying to stain some of the areas that show white but I haven’t came up with a fool proof plan as of yet. Since the walnut is sealed, I could probably use a qtip and push some stain into the cracks and then give it a quick wipe. Might try that on an inconspicuous area.
Your stern really turned out well.Getting close to the finish line. 5 cannons and the rudder, which I had to remake out of scrap because I apparently lost the original one, is about all I have left. I worked on the base today. Simple Oak with a routed edge and I turned some maple and resin pieces to make the notched stands. I am going to source a display case eventually. Mounted a shelf in the office for its permanent docking station. Also added the rope railing around the fore deck.
Nicely done. Keep at it!Been working on the rudder. Mounted the hinges and am in the process of places the nails. This is quite time consuming for me. Those little nails are extremely hard to place in the holes and get them to stay but I’m getting there. At about the 130 hour mark.
