H.M.S Enterprise / Enterprize. 1:96 (Modelship Dockyard)
Grant, thank you for the compliment. It is just that I am enjoying research more than ever before.
From what I recall of my Greek history (I just looked it up a minute ago:)) the reason HMS Medea has a woman as the figure head is the name. The name is from Greek mythology where Medea was the sorceress and enchantress who helped Jason obtain the Golden Fleece. It seems that if the name of the ship has no significance a lion was often used, but not always. It was certainly the predominant figure head for British ships for decades. Peter Goodwin gives a full page of history on figure heads on page 205 of The Construction and Fitting of the English Man of War. In short, prior to 1727 figures other than lions was limited to First Rates. Starting in 1727 restrictions were moderated in that any size ship could have a figure head suited to its name. Crowned lions were still predominant. By 1796 figureheads were abolished on new ships due to costs and busts, half figures, or scrolls were the only things allowed. Gilding figureheads ended about 1760 when painting them became the norm as it was more protective than gilding and less expensive.
For Enterprise 1774, the Joseph Marshall painting of 1777 shows what appears to be Perseus carrying the head of Medusa.
1st deck layer done. Hatches and ladder access es framed with walnut to make it Pop.
Courtesy and thanks from gventura’s build log on this forum.
I just went through your build-log, Neil. What a nice and fine job on this scale.
2nd deck nearly finished. Some middle beams were a tad short by 1mm.Either the whole middle section has widened slightly since coming out of the cradle or my misjudging.
No big deal as it was literally about four or five.
Any way onwards, as life is too short to over nitpick.
Instructions are a bit vague to say the least, some parts not labelled and some on different plates.
Here’s the latest.
Here’s the latest.
Hi Neil. Very neat and beautiful symmetry. Cheers Grant
Neil,
Your workmanship is SUPER and the details had me wondering if are using the original contract as a reference as well. I know there was reference to it previously but if you do not have it and would like a transcribed copy please feel free to give a shout. I posted it the other day on another thread here at SoS as well if that is easier.
Looking forward to the next update photos!
Neil,
Many thanks Allan.
As you know, I’m not building a museum piece here. The scale is so small and the instructions are very vague as are the parts.
There seems to be many different re-editing of the instructions without actually changing the contents of the kit.
Tis a struggle to understand a lot of it.
Eeeeek !
Fiddly but slowly getting there.
Did away with the supplied side planking and used my own stock. A lot easier to work with.
Couldn’t understand which way they were meant to be laid.
Third deck work begins.
Forecastle beams now being installed.
Working out okay so far.
Few other tiny pieces to help break up sore fingers.
Been busy on the outside planking. Took a bit of time to sus out which planks are for the port side and which for the starboard.
Got there in the end.
Port side done, with a quick sanding, now for the other side then a final sand and hopefully will come out ok.
Some pics.
