Wow Bryian! A nice kit to be sure - but your work is also exemplary. Keep it coming!
Hello Heinrich, the frames are already bevelled and ready for assembly. I will clean them up with fine sandpaper after the glue has set.Do the frames come beveled, or it is that left to the builder, Brian?
Does yellow tang wood lend itself well to carving like boxwood? Perhaps it would a make a suitable substitute.Good day friends,
I have started assembling the bow structure pieces. This Yellow Tang wood is really something else. It sandpapers to a porcelain like finish and its really hard, holds an edge easily and looks like English boxwood.
The model has timber-heads already milled on the top edge of the frames. It only required a slight touch with sandpaper and then its ready to fix in place.
.View attachment 317577
WOW! What a dedication to details @DaHaimodelThe model has timber-heads already milled on the top edge of the frames. It only required a slight touch with sandpaper and then its ready to fix in place.
Hi Kurt,Does yellow tang wood lend itself well to carving like boxwood? Perhaps it would a make a suitable substitute.
Dear BryianGood day friends,
Rough estimate,maybe in 6 months ,but that is not written in stone!Bonjour Peut-on envisager une date pour la commercialisation ?
Cordialement et félicitations pour votre travail
Gerard
Hello Can we consider a date for marketing?
Regards and congratulations for your work
Gerard
I agree with Maarten, this is a one-of-a-kind kit (thus far), and can be built to a high-grade model without bashing (out of the box)! I look forward to seeing the progress...the more details the better!Hi Brian,
Please don t be to enthausiastic and show us all these fantastic details.
I know where this ends........I have to get this kit.
This can be build into a seriously nice navy board model in a full box wood appearence.
I have to comment on this... It is not just you are offering something very different and technically new engineering way for the kit, you are actually offering an optional choice of timbering set? Am I correct? Does this mean you can take orders for a choice of timber?In fact, we have prepared quite a lot of Asian boxwood. Although I can't compare it with English boxwood now, but it is quite close to English boxwood in terms of density, fineness, color, engravability on text description. This boxwood is used as high-grade wood for carving crafts in China. For modeler with high-end requirements, I think we can provide components in a customized way-full boxwood kit.
Jim,I have to comment on this... It is not just you are offering something very different and technically new engineering way for the kit, you are actually offering an optional choice of timbering set? Am I correct? Does this mean you can take orders for a choice of timber?I hope I interpreted it correctly...
