Heller Victory
I am building the Heller Victory plastic and wood. I need some advice for the rigging. Especially on the hullen.
Many greetings, Albert
Welcome to the forums Albert.
Can you be more specific as do your needs with the rigging? There is a lot of it on the Victory.
You should start from the inside and work your way outward.
Use a highlighter and mark the ones on the plans as you install them.
How far have you got with your build, Albert? This is a good place to maintain a build log, you will receive a lot of good advice from some very knowledgeable people.
