HI FROM TASMANIA
The Zap Z-Poxy is the only one I will use. My hulls are generally a combination of frame and bulkhead sheeted with 1/32 plywood. After filling any imperfections in the hulls with automotive spot putty and sanding down I cover the hull with 3/4 oz glass cloth, apply usually two coats of resin with a little more sanding and spot putty if needed, prime and paint. This method works well on my tugs, freighters, and military craft where a welded steal hull is represented. As to your other questions, return to the Great Hobbies site marine section and have a look at the running hardware kit for the DUMAS tug Brooklyn. I built this tug years ago and it performs flawlessly using that gear. In the future I may start switching my drives over to brushless motors.
Many thanks!
Hi,
Just had my first experience with Z-Poxy.
What a great product this is. I am currently building the Anteo 2 from Mantua/Panart and decided to make the hull waterproof.
First I thought about using polyester, but with polyester there is a risk of not sticking to wood properly without the application of a primer.
After seeing a video on YouTube of modellers using Z-Poxy I decided to switch to that.
This is how I worked.
After sanding the hull with rather coarse sanding paper (I used grit 80) I took away the dust with a vacuum cleaner and applied a coat of Z-poxy with a flat brush on one half of the hull.
The Z-Poxy partially soaked into the wood and filled the small gaps between the planks.
Then I put down a fine glass fiber cloth (which I obtained from Hobby King). It soaked itself into the Z-Poxy. I used an old credit card to stretch out the cloth over the hull and take away any excess of resin. To swipe of the credit card I used kitchen paper with I immediately disposed into a bin just aside me.
I did not put any cloth over the keel, but cut it of using a sharp hobby knife just in the corner of the planks touching the keel.
The other side of the cloth I just left hanging over the edges as I decided to cut that after drying.
When dry I did the second half of the hull.
After drying I cut off the excess of cloth and sanded the hull.
When sanding I discovered some small voids under the cloth witch I removed using a razor blade and sanded it down a bit.
Then I applied a second coat of resin. Again just using a brush. I is a amazing how the resin stretches out and removes the brush traces.
Just sand it again and done.
I attached a picture of the hull after applying the cloth with the first coat of resin.
Nice job! As you say there is no reason to apply fiberglass cloth to the keel, rudder, and other difficult places. A couple coats of resin adequately seals them from water.
