Very nice work Heinrich, but, out of curiosity, the nails of your galleon railing, ar they a bit to long, or are they going to be covered bij inner planking??
You are right Jan. It is indeed satisfying, but because it is "finishing" touches, they are all very visible, so I am taking my time not to mess up here. And even though it is not extraordinarily difficult work, it can still bite.Nicely done. I like the looks of the "final" touches. It must be very satisfying to have all the pieces come together to bring the little ship to life.
Thank you my friend and you ask a very good question about the nails. They are indeed too long. Once the glue had dried properly, the part that extends into the hull will be cut off and filed flush.Very nice work Heinrich, but, out of curiosity, the nails of your galleon railing, ar they a bit to long, or are they going to be covered bij inner planking??
Good morning Heinrich. I was thinking the same thing. Would it not be easier to cut the nail to length and drill a hole also to length - adjusted the drill bit in the drill very short. Then it won’t go through? No filing and and cutting after the event.Cheers GrantThank you my friend and you ask a very good question about the nails. They are indeed too long. Once the glue had dried properly, the part that extends into the hull will be cut off and filed flush.
Hello Grant. You are beginning to sound like a real model builder!Good morning Heinrich. I was thinking the same thing. Would it not be easier to cut the nail to length and drill a hole also to length - adjusted the drill bit in the drill very short. Then it won’t go through? No filing and and cutting after the event.Cheers Grant
That would be absolutely the correct way of doing this, but I do not see myself going to that trouble. I far prefer to do it the "freestyle" or "boer maak n plan" way. Let's first act and worry about the consequences later! Seriously though, I have very sharp and small side cutters which will take care of that for me.
That is most interesting Peter - thank you very much for that.As we say in Dutch: there are many roads to Rome:
the shortest, the fastest, the prettiest, the most efficient ......... but like Heinrich: "I did it my way".
Ps: the original song is not from Frank Sinatra. It’s from Claude Francois: ‘Comme d’habitude’.
If memory serves...on the first (your first) WB the aft canopy had hard corners and the fore canopy had soft corners. Here you have hard corners on both. To my eye the consistent construction makes more sense. Would they have made a canopy with soft edges if it served no purpose other than esthetics? I'm guessing not.Dear Friends
The front canopy roof has been covered. I suppose it doesn't look bad, but I'm not sure if I am convinced. I am not worried about planks which do not lie completely flush or flat at this stage - that will all be tended to with the second sanding session (I just stained it so long to get an idea of how the overall effect looks). I am more worried about angles and if this particular layout, doesn't make the canopy appear too boxy.
Once again, you display a very keen eye, Paul! I am happy with the four hard corners as that is what it should look like.If memory serves...on the first (your first) WB the aft canopy had hard corners and the fore canopy had soft corners. Here you have hard corners on both. To my eye the consistent construction makes more sense. Would they have made a canopy with soft edges if it served no purpose other than esthetics? I'm guessing not.
But, what do you think of your lattice pattern here? Are you happy with that aspect?
The sides - (and the two front corners to be specific) are my issue as well my friend. No need to apologize - please say it like it is - that is what I appreciate.The largest part of your canopy is looking excellent, but i am having my doubts about the sides.
At this moment it looks like you had 2 roofbeams to short. (sorry about my comment )![]()
Hah, i probably would have used a much bigger nail.Hello Grant. You are beginning to sound like a real model builder!That would be absolutely the correct way of doing this, but I do not see myself going to that trouble. I far prefer to do it the "freestyle" or "boer maak n plan" way. Let's first act and worry about the consequences later! Seriously though, I have very sharp and small side cutters which will take care of that for me.
I think you're right: redo-time.
Absolutely, Johan!I think you're right: redo-time.
Thank you, my friend. I will gladly comment.Good afternoon Heinrich, I allow myself these observations, I have no feedback on them? Thank you
Thank you, my friend. I do not know why I am struggling so much with this build. At times it just feels that NOTHING wants to work as planned.Goodluck on the next roof Heinrich
