You are welcome. Yep we have to make that jump to POF ships at least once. If we don’t like it at least we gave it a shot.
Good morning Gilbert. Thank you kindly. It is always a pleasure to have to on board
Good morning Alan. Thanks for this. I did read through the Aurora contract and check somethings against the kit. It was from this that my disappointment arose as the kit detail is far removed from the actual specs. E.g the frame construction is way out with no chocks and the futtock being the same width with a simple overlay construction etc, let alone the frame width being too large. That being said it is my first POF and I am excited to just build one according to the kit. Let see what goes.
Good morning Neil. Thank you. I have been following your build and kudos you are owning the project.
Good morning my friend. It is always good to have you on board….I appreciate your input.
Hi Graham. We all have to give a POF a go sometime……in my case may be a fool’s errand
…we shall see. Thanks for checking this build out.
Good morning my friend. Thanks Roger. Let’s hope it will be a good adventure.
Thank you Snowy.
Good morning. I agree there are some very helpful concepts CAF have added into this kit - let’s hope they help me along the way.
Yep Zoly is correct there are a few completed build logs here.
@Bryian built a cool one.
Good morning Alex. I may well be asking some questions and learn from your process. I look forward to seeing your progress as I think I’m going to need all the help I can get.
I do have a little “buyers remorse” after seeing Dockyard has now released the1:48 kit. I think it adds so much added detail and accuracy. That being said I am excited to give this a try.
Welcome Paul always a pleasure. I think Arlene would be ecstatic if you redecorated my hobby space….. she just rolls her eyes when she enters my shipyard lately
Hi Jack. At the moment there are 3 POF enterprise models out there (all Chinese). Model Dockyard makes a 1:48 and a 1;96. These are more accurate kits with regard to internal structures and give more detail on the interior at all deck levels than the CAF version. The CAF 1:48 is an older kit from Cherry wood and has a different outcome to the others giving an outward POF museum finish with high quality upper deck finishes.
Thanks Russ. Welcome aboard. Hopefully we have smooth sailing ahead….
Cheers Grant
