HMS Enterprise 1774 POF 1:48.
Your work is outstanding Grant. I believe there is a lot to be said about using old fashion modeling hand tools, we all know the original craftsmen of the real thing had no electric saws or routers so to me it's highly probable you are producing a model much closer in appearance to what was being made back in day. Having said that, I too prefer using those very handy electrified helpers, without them I would probably stick to plastic.
Grant you are being a bit hard on yourself, but sometimes that can be fopr the good. I really like what you have done so far, but equally I am sure the changes you make will make things even better. I guess it is to do it as you like it.
Respect JJ..
PS That was some win over the sheep shaggers.
Good morning Jack. Thanks for the compliment and having look at my Royal Navy frigate attempt. One thing for sure is trying to make these kits more accurate tests my skills to the limit. I find my finishing is not as good as if I just used the kit but I get more satisfaction - a bit like the old Lexington ad :” after action satisfaction “. Cheers Grant.
PS Yea- SA rugby is having a golden run at the moment- long may it last:D. You guys got a cool draw for the RWC especially for the quarter and semi- maybe this will be your time.
Your wales look great Grant. Nothing wrong with them imho.
Was Indian ink applied one time or do you need to apply it several times?
You are right you will need cutting and milling tools, but most of my work is still done with a scroll saw for the rough work and hours and hours of filing by sight to get a good fit. But no one is 'accusing' me of an efficient working method ROTF.
Good morning Herman. Thank you kindly. I thin down the ink with water and paint it on with a brush - let it dry for about 10min and then with a wet rag I rub it into the wood. This gives it a more Matt look, takes any irregularities out and makes the grain and joints more visible. I only use one coat.
My carpentry skills are lacking so machines are needed in Grants shipyardROTF. Seeing how you build, your efficiency is just spot on.
Cheers Grant
I hope you are feeling very satisfied with this effort, Grant! The specialty planking of the wales looks fantastic and in accordance with the period and style of the ship. Bravo on making this important change - and for doing it so well!
Thank you kindly Paul. My hand cutting creates some deviations with each plank. (Those shipwrights of old certainly had skills) I need to improve this so I don’t spend hours sanding. I am pretty happy with the outcome however as I said to Jack the finished product is not as neat and tidy as if I used just the kit parts. Much more fun to:D. I also need to be more careful when buying the timber and look for wood with smaller grain. With this walnut I bought the grain tend to lift and it is a mission to finish off. Trial and error….never stop learning. Cheers Grant
Hey Grant, :D
What you've done so far looks really great. The bark wood and anchor stock planking also look very good. I'll keep that about the ink in mind. I really think it looks authentic... Awesome...:DThumbsup
I know only too well how we get caught up in the madness of wanting to make things even better. But always be careful, it can also get worse...
Good morning Gunther. This is a true story. My decision with this build was to attempt to build it as authentically as possible. This has meant that almost everything on the kit has been changed or scratch made and there is a distinct possibility that some things will visually look worse than if I just stuck with the kit. I will label this ship as Grants practice/learning Frigate….. Way more fun than just gluing planks to frames :D. Cheers Grant
Hey Grant,
That looks bloody good!! Very nice. But I think, like everyone else, that your Enterprise is not a “practice ship”, but a feast for the eyes with outstanding build quality, which you show here. Simply top notch, my dear!! Thumbsup
Catching up on your build Grant. I think she looks fantastic, don’t be too hard on yourself. Remember when it’s finished there will be so much to look at and take in, that no one will notice those little imperfections you agonize over. Most of us strive for perfection, and that is part of improving your skills and getting a good end result. Go for perfection and settle for your best! ;)
Hi Grant, just got caught up on your build. Wonderful work mate! Very clean execution. I have to applaud you deciding to "redo" certain elements, not because they were sub-standard, at all, but because you felt you could improve them. Well done on the decision and well done on the quality of the outcome. I feel I can speak on this subject as I've become somewhat of a knowledge expert on removing and reinstalling planks, sometimes more than once!
I enjoy visiting your thread, not just for the eye candy, but the entertainment, in general! Keep it up mate! Oh, congrats on 21 years of your business. Businesses don't last that long unless they are doing things the right way!
Good morning.
Started working on the thick stuff above the wales and redoing my gunports.
I change the kit strakes around the gunports to get it more in line with a Frigate of that period.
Cheers Grant
A nice re-do and personal touch, Grant. And changing guns from port to port is also nice to see ……… ;)
Good morning Dean. Thank you kindly. That is sound advice. Luckily I’m not a perfectionist otherwise I would be going more mad than I am already. Cheers Grant
Good morning Ken. Good to chat with you again. I am attempting to get more structural accuracy in my modelling vs just applying regular planking to the frames. It is a steep learning curve for me as I can no longer get away with slightly askew measuring. As for milling wood……ROTF. Cheers Grant
Your not supposed to be cutting your hand. I thought you had enough of that. ROTF
Oh, you mean cutting BY hand, not cutting ON hand....
Your ship is looking great !
ROTF. Thanks Jeff.
Good morning Peter. Thank you kindly. Whew it is taking a long time to get these ports accurately redone. Testing my abilities this ship:D
Cheers Grant
Good evening. I am continuing with the gunports and the “thick stuff” on the bulwarks. I have left open the planks corresponding to the open ones on my inner planks so you can see through.
You will see I removed my wales. A bit of a mess left for me to clean.
Excuse the saw dust I did not brush off very well.
I still have to tidy up the ports and straighten some- my cutting not %.
Cheers Grant
