Always such nice work Peter...
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
The books are great and all the plans are excellent, but Volume 1 is sold out. Maik from Sea Watch answered my question last summer and said that he was already planning to reprint part 1.Your work is looking very interesting -> means very good work on an interesting ship -> means maybe I should order for me also the books about the EURYALUS
Did you make the notches on the keelson by hand or with a mill?
Looking at your table we can see a lot of wooden chips, so I interpret by hand, or?
It is making less sense to have only Vol II available - so I can hope that Seawatch will reprint also the first Volume .... many Thanks for the informationThe books are great and all the plans are excellent, but Volume 1 is sold out. Maik from Sea Watch answered my question last summer and said that he was already planning to reprint part 1.
All by hand. Using side template, I score with a scalpel then saw with an ultra fine razor saw (70+tpi) then chisel with 4mm wide chisel. Finally cleaning up with a 6 or 8mm wide diamond file. I do have a mini mill but I like working by hand when I can. Very therapeutic….Your work is looking very interesting -> means very good work on an interesting ship -> means maybe I should order for me also the books about the EURYALUS
The books are available on the second hand market: Amazon has one set of V0l 1 an 2 for $350 used in very good condition.It is making less sense to have only Vol II available - so I can hope that Seawatch will reprint also the first Volume .... many Thanks for the information
That's the luxury of the Dremel scroll saw. The blades have a 0.5mm kerf. This means it takes a little longer than using a full size scroll saw but I have much less wastage and can get close to the lines without resorting to the fine blade which I have found wanders too easily. It also means that in many cases, I only have to make one cut for one side of two frames which also saves time. It takes about an hour and one blade per plank which vary from 5.8 to 7.4mm thick (a scale 11"" to 14").Ja Ja - that is scratch POF modeling ......
I suggest to start first with the cutting out with one board and your new saw as a test.
You have to check, if the distance of the frame parts glued on the board is maybe not to small.
Sometimes it is easier to cut and handle when you have more distance between the elements - you need maybe more wood, but cutting out is faster and easier.
Are you using a jigsaw or a scroll saw for cutting the Frame elements?
Would have made more today but the superintendent decided she needed to go to IKEA for a new footstool since I elevated the lounge 3in (75mm). Well needless to say we didn't get out of there for several hours and a boot load....Excellent progress Peter.![]()
Sounds interesting - I never tried it in this way.That's the luxury of the Dremel scroll saw. The blades have a 0.5mm kerf. This means it takes a little longer than using a full size scroll saw but I have much less wastage and can get close to the lines without resorting to the fine blade which I have found wanders too easily. It also means that in many cases, I only have to make one cut for one side of two frames which also saves time. It takes about an hour and one blade per plank which vary from 5.8 to 7.4mm thick (a scale 11"" to 14").
The blades do get hot cutting the cherry and fatigue if I run continuously for more than 30 minutes. I cut for 10mins take a 5min break then continue but by the end of the hour, the blade really starts to take its own direction (as it gets blunt) .... Thankfully I have 15 spares on hand.
I have already cut out 2 of the 11 boards (yep got all the templates stuck down last night) for the aft frames with one blade failure. The second is getting a little blunt but I will continue with it until it slows or wanders.
. Respect to all the scratch builders out there!
Nope. They are all scale thickness from 11"" to 14" and some 1/2" in between. This does not mean that all the futtocks on the one frame are the same thickness. In fact most frames have floors, futtocks and top timbers all different thicknesses and which side they align varies depending on where in the hull the frame is located.Just curious Peter - are all the cherry panels the same thickness? Scarf joints? Chocks? Butt joints? I'm working on my first POF and I'm in learning mode...
BTW, your picture makes me a bit nauseous just thinking about how much work that is. Respect to all the scratch builders out there!
