Heh! Me too!In the meantime, missing your work, Kurt!
**VIEW THREAD HERE** |
I think I'll abandon using Blender for making 3-D models to print for the decorations in favor of using a much simpler program, Aspire. That program is made primarily for CNC routers, but can make the flat decorations for the Sovereign with reasonable detail. Why the switch? Well, I saw Tuvok's model based on the Amati plans for the Sovereign, and his results using Aspire are very good! I am super impressed. His build log in in Italian, on Modellismo IL HERE. Anyone serious about doing correct reproduction of the decorations on the Sovereign should check it out. As promised, when I eventually get the decoration 3-D files done for my model, they will be made available at a modest price for other modelers. They won't be up to @SZKUTNIK's standards, but they'll do.
Tuvok based his decorations on McKay's illustrations, which parallels my approach to making them:
Here are some of his results, made using a 3-D resin printer. I will copy his example:
Tuvok made vector drawings for the friezes in Aspire, then formed them into 3-D objects. I can't carve, so this is a good alternati
I know that Vectric Aspire has many versions(and prices) available. Which version were you thinking of buying. I have the Vcarve desktop version. So far all I have done is created small signs with it and my mini CNC machine. It's more complicated than I thought it would be. My machine does not have limit switches so I am always checking the cut path to make sure I don't break anything. Set z=5, or something above 0, which is the table and run just XY to see what happens.The Tuvok model is pretty remarkable in a number of ways. Unfortunately, he followed the McKay suggestion for the lower transom; square tuck sterns don’t look like that.
The ornamentals are incredible, though.
I don't have a CNC mill, so 3-D models will be created and printed on the 3-D resin printer (once I know what to do).I know that Vectric Aspire has many versions(and prices) available. Which version were you thinking of buying. I have the Vcarve desktop version. So far all I have done is created small signs with it and my mini CNC machine. It's more complicated than I thought it would be. My machine does not have limit switches so I am always checking the cut path to make sure I don't break anything. Set z=5, or something above 0, which is the table and run just XY to see what happens.
I also have to double check the gcode just to make sure I don't get garbage in the file.
I have two choices now that I am looking at this. One is to use Vcarve to make the pieces or two is to make molds and create parts with resin. There is a fellow, Jay, that is doing this second choice and he seems to be getting really good results:
ZHL Le Soleil Royal
Welp, I received the Soleil Royal from ZHL today. It took 8 days from shipping date, pretty good I think. Thought I would go ahead and start a build log and show the packaging. Still need to do an inventory of the parts. Won’t start working on it till I finish the Black Pearl though.shipsofscale.com
What's worse is he reworked his entire hull and put a square tuck on and removed the round tuck. However, he removed the decorations made with hardening putty (which looked really good) and is replacing them with 3-D resin printed decorations designed using Aspire, and those are a bit better.The Tuvok model is pretty remarkable in a number of ways. Unfortunately, he followed the McKay suggestion for the lower transom; square tuck sterns don’t look like that.
WHAT? You're NOT my biggest fan yet? How disappointing...If you can duplicate the results shown by Signor Tuvok I will become your biggest fan. Those look fantastic! Looking forward to seeing what you come up with Kurt!
Learning to print in 3-D is a learning curve in itself. I bought a nice 8K 3-D resin unit and have a time learning the set up process.I don't have a CNC mill, so 3-D models will be created and printed on the 3-D resin printer (once I know what to do).
I never thought of that. Good ideaI don't have a CNC mill, so 3-D models will be created and printed on the 3-D resin printer (once I know what to do)
Looking forward to seeing yours!I think I'll abandon using Blender for making 3-D models to print for the decorations in favor of using a much simpler program, Aspire. That program is made primarily for CNC routers, but can make the flat decorations for the Sovereign with reasonable detail. Why the switch? Well, I saw Tuvok's model based on the Amati plans for the Sovereign, and his results using Aspire are very good! I am super impressed. His build log in in Italian, on Modellismo IL HERE. Anyone serious about doing correct reproduction of the decorations on the Sovereign should check it out. As promised, when I eventually get the decoration 3-D files done for my model, they will be made available at a modest price for other modelers. They won't be up to @SZKUTNIK's standards, but they'll do.
Tuvok made vector drawings for the friezes in Aspire, then formed them into 3-D objects. I can't carve, so this is a good alternative.
