Happy Birthday, Chris!  Have a wonderful day!
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Thank you, belatedly,Jimsky, it was a good day, being my 70th, so sorry to have missed your kind post, but am now ‘back on the job’ and enjoying it no end. Hope the world is being kind to you in the current environ.Happy Birthday, Chris! Have a wonderful day!![]()
Hi Chris,Thank you all for your kind messages, just found the above anniversary postings etc, I am humbled, It must be said that I have been absent from the both the site and model building for some little time, however now am back in the ‘ swing of it’, I do apologise for not seeing the posting earlier, but have not been on the site for ages due to sad personal events.
However, am now enjoying the considerable challenge of this model, in this respect I will upload a few pictures of progress to date.
May I ask, with new postings to my platform, will I be able to access the personal site easier, as I had to search through several pages of later posts. Thanks guys, speak soon.View attachment 146959View attachment 146960View attachment 146961
Thank you Maarten, still trying to fathom out how to navigate the site, have a great day.Hi Chris,
Welcome back.
If you quickly want to find your blog go to the main menu and click the "your thread" button. You then find a list of all the topics you started.
Hi Chris, there will be wales also these are most probably from thicker strips reducing the number of veneer strips needed.Hi Guys,
Just spent some time going over Jimsky’s posts regarding the Charles Royal yacht build with particular interest in the , brilliantly detailed, second planking process, as after completing the gun deck etc I will be looking to start the second planking.
I believe that the first planking was probably from Lime wood, Tillieul in French, which is a lovely fine but soft wood, ideal as it sands well.
The supplied wood for the second planking is a hardwood of some sort, certainly not as stated, but that’s , by-the-way, it still posses several questions, not the least, how to proceed, hence my interest in Jimsky’s post, there are no doubt others, but this will be for further study, my aim is to formulate a , modus operandi, soonest.
There are very interesting and evocative details shown by the post referred to which will be greatly helpful. not least to myself.
So, a huge thank you to Jim, you have given me much to ponder,
The supplied planking wood is 4x1.25 mm as far as I can see, by vernier gauge, there are 53 strips supplied which will cover 212 mm, measuring from the keel to the gun ports we have 120 mm each side, that appears to leave me short of boarding, by some 30 mm , conundrum !!. Has anyone else had this problem with this build? .
I guess matching the wood will be nigh impossible, looks like one has to purchase a complete new batch of wood,
Interesting!!.
Hello Chris,Update from the work of this week to date, Have now placed all gun ports and boarded up to the strake at upper deck level, all good. I have fitted the upper deck to eventually drop into place, but still loose as the gun carriages must be fixed first.
Thinking ahead to the rubbing strakes, trying to determine timber sizes etc , it now seems possible the read the list found on Plan 1 , having parts numbered 1 to 33, these are all in Italian but once one understands a little, all slips into place, the list gives all part numbers, as detailed on the plans, with , Quantity, Material used, Sizes and Codice, which I have not yet cracked, but probably will not need to, this list to part 33 is continued on drawing Plan 3, et all.
So we find the part number, part description in Italian, no,problem there as the part number is on the plan so a visual connection may be made, col 3 has the parts material, wood, metal etc, for the wood there is a code system such as. LM. = Mahogany Lath, LN = walnut lath, NO = walnut wood part (distinct part not lath), then the 4th col is the parts size. Voila, so part 51 of detail 8 on sheet plan 2 is a pre formed plywood part, part 52 on the same sheet of detail 9 is Walnut 4x1 section lath.
I understand that plans may differ with kits, but this gives a clearer ,I hope, manner of finding component parts and helps also sort out the kits stock of woods etc.
finally a couple of shots of the gun ports in place and the loosely fitted upper deck, knowing which pieces of wood to use now I can proceed with the strakes below the gun ports prior to starting the second coat of hull planking. I should also note that the stern transom parts are also unfixed, held in place with rubber bands for clarity and sizing of the planking, it is still possible to place all gun carriages after the hull second planking is finished up to the gun ports, but before the deck and transom are fixed, which will then make the building up of the upper sides simpler, the tumblehome etc.
Hope this helps, particularly for you Bill, as you are building the same kit at the moment, likewise for any future interest in this lovely project.
View attachment 147740View attachment 147741
Hi Chris. I just started this model, so far so good. I'm in the early stages which means planking of the gun deck level. With so little of the gun deck actually visible I'm curious why you choose to plank from stem to stern. Just because you'll know it's there?
Cheers
Hello Chris. It is very cool to meet a model builder from Malta!!! A very famous place in history!!!I live on the second of the Maltese archipelago's islands, called Gozo
