considering all 6 sides are the end grain it all soaks up moisture and it's the resins that are the bad parts, I mean worse than the saw dust it's made of
Try aircraft spruce plywood they are in Toronto and the sell top quality wood in metricAfter Lady Nelson I am collaborating on another scratch build with my brother. A Great Lakes "propeller". I want to try using mdf sheet for the framework. We had some trouble with getting the right plywood on the last one. Does anyone know from experience a source in Canada for 4, 5 or 6mm thick mdf with excellent thickness tolerances and finish? I'm not sure how to spec it out. Is it high density?
Thanks for that tip. Closer to me now than Cambridge (A&M Wood Specialties). I will give them a shout.Try aircraft spruce plywood they are in Toronto and the sell top quality wood in metric
Do they have a web site?Try aircraft spruce plywood they are in Toronto and the sell top quality wood in metric
This must be them, but they are not in Toronto, they are about an hour away in Brantford, home of Wayne Gretzky and Alexander Graham Bell.Do they have a web site?
They must be famous just for their locationThis must be them, but they are not in Toronto, they are about an hour away in Brantford, home of Wayne Gretzky and Alexander Graham Bell.
Thinking of all the dust....I buy 5mm sheets which are readily available at the local hardware store, then rip it into small strips and then run it though by thickness sander.
That way I can get it down to 1.5 mm thickness.
Not if you use a vacuum attachment on the Byrnes thicknesserThinking of all the dust....
Yep, we have the link. It not only to me, it is for all members of SOS, should they ever need it.I put the link up above a week ago, Jimsky should have it.
