I started with the kit provided steering wheel...and quickly discovered the central hub was not provided. Of course, it is no great difficulty to make a circle with a hole in it:
I then added the kit-provided spokes and the outer ring:
I wasn't too excited about this look, so I tried to round off the outer ring:
Hmm...not exactly a high-precision outcome
After a bit of research and the accumulation of the requisite level of courage...I decided to give it another shot, but this time using milled parts. I created four 'worktables' that would fit into the dividing attachment of my mill. Each of these 'worktables' had a boxwood board attached to it with rubber cement (three with 1 mm box and the fourth with 2 mm box):
Time to make some circles:
All four:
Now I needed to mill 1 mm slots in the 2 mm board to receive the spokes (every 36 degrees):
Here is the 2 mm hub and the 2 mm outer ring with loose-fit spokes - the opposing 1 mm outer ring sits to the left:
So why did I make four rings? Two of the rings were just
barely dimensionally narrower than the main outer rings - I was hoping to use them decoratively. Here you can see one added to the main outer ring:
Next, I thinned down this decorative ring:
Progressing...
I decided to go back and add some details to the decorative ring:
The kit-provided wheel is to the left:
Below you can see the built-up stanchions and a central barrel where the rope will wrap (I made the barrel on the mill with the dividing accessory):
And now all the parts glued together:
And finally, sitting loose on the ship:
That's two full days of my life sitting there. I have now removed this breathtakingly fragile wheel and placed it into storage.
Thanks for the visit! You are a fine bunch!
