Kingfisher 1770 1:48 POF
Hello Friends,
Things more important than ship modeling (blasphemy!) have kept me away recently. In recent days, however, I've been able to steal away a few hours here and there to work on the chains.
A photo essay capturing a few of the steps:
This remains a work in progress. The chains associated with the larger deadeyes still need something on the lower end called a preventer plate. About two weeks ago I ordered some dimensional brass strips from a supplier in Germany, and as of today my order is still in Germany. To that end I needed to move on to something else as I await the delivery.
That something else was an anchor.
The kit does include an anchor to be made from boxwood - and I suspect I could have managed to create something presentable out of wood. But I am always aware that I need to develop new skills, so I took a shot at making something from brass.
Here is a drawing from TFFM (Antscherl) showing a 20-cwt anchor (that's 2240 lbs. - just over a ton).
I transferred that image to a 3 mm thick sheet of brass and cut that out using a coping saw (fret saw?):
Since my saw work was pretty lousy (I also burned through about a dozen blades on this lark of a project), I needed to spend the next several hours cleaning this thing up:
After a bit of soldering and some clean-up work:
And that's it for now. My next opportunity at the workbench will take a shot at the anchor stock.
A true jack of all trades!
The smallest of updates... an anchor:
It would seem that I am the only builder on the planet who cannot wrap the ring of an anchor with rope well. I'm now 0 for 2:
Mr. Antscherl (The Fully Framed Model book series) argues that there should be a tapered split between the two halves of the anchor stock for water drainage. Makes perfect sense to me so I did it...
Parting shots:
Thanks for the visit!
You say:
"The smallest of updates... an anchor:"
Not only a master of wood and metal working, but A MASTER OF UNDERSTATEMENT also!!
Not simply an anchor, but a custom, handcrafted and highly accurate work of art. I am particularly impressed by the "split" for water drainage. Never would have thought...
Well done!
Parting shots:
The smaller the update the greater the reactions……. ;)
The ‘blackening’ of the brass came out very well, Paul. A nice deep soft coloring.
A split part is most of the time a reason for a big shout AUCH. Now its a big shout WOW. A nice detail. I suppose we will see this soon on more models ….:)
