L'Artésien - Vaisseau de 64 canons 1/48 scale
WOW! Excellent craftmanship, and many thanks for sharing the entire process of making frames. So...if I understand you correctly, you
are using only copying saw to cut frame
WOW! Excellent craftmanship, and many thanks for sharing the entire process of making frames. So...if I understand you correctly, you are using only copying saw to cut frame parts?
Yes, I mainly use this saw. I do have a Hegner saw but I find it too noisy.
But the Hegners are doing very good work - I have also one....
and you are doing very good work on your model Thumbsup
