L'Artésien - Vaisseau de 64 canons 1/48 scale
WOW! Excellent craftmanship, and many thanks for sharing the entire process of making frames. So...if I understand you correctly, you
are using only copying saw to cut frame
WOW! Excellent craftmanship, and many thanks for sharing the entire process of making frames. So...if I understand you correctly, you are using only copying saw to cut frame parts?
Yes, I mainly use this saw. I do have a Hegner saw but I find it too noisy.
Thank you for all your encouragement.
Here are some photos to show you the situation today.
As you can see, I am making a model that will be partially finished so you can see the interesting details.
A previous photo shows the parts just installed and not glued.
In the next two photos, they are definitely stuck together.
View attachment 438898View attachment 438899
On the other hand I drilled the locations of the pump feet.
The four holes for the pumps on the main mast were easy to do with a drill, but for the two on the jigger-mast it was a little more delicate and ended up using needle files.
View attachment 438900View attachment 438901View attachment 438902
To follow manufacturing of a knee-rider. The assembly and gluing of the parts is done on a sheet of bristol 160gr/m2.
View attachment 438903View attachment 438904View attachment 438905View attachment 438912View attachment 438913View attachment 438914
View attachment 438915View attachment 438916View attachment 438917View attachment 438918View attachment 438921View attachment 438928View attachment 438931View attachment 438932View attachment 438933View attachment 438934View attachment 438935View attachment 438936View attachment 438938View attachment 438944
