Looking for round files 0.4 to 0.8 mm
  • Thread starter Thread starter Y.T.
  • Watchers Watchers 15
Toronto, Canada
Hi, could someone please recommend where I can buy round files 0.4, 0.5, 0.6, 0.7 and 0.8 mm? I need high quality files to tool out some grooves for stropping the rigging blocks made of wood.
I don't think you can find files for such small sizes (I have never seen such). However, look for the escapement needle file. althought they are tapered but can be as small as 0.3mm at the beginning and 1.9mm at the end.
This one made by Corradi (Italy), but I know Grobbet and Vallorbe (Swiss) made them as well. Most jewerly store should carry them. They comes on diffrent cuts, from #0 (very coarse) to #5 (very fine).
Look here:
Post in thread 'La Créole 1827 by archjofo - Scale 1/48 - French corvette' https://shipsofscale.com/sosforums/...o-scale-1-48-french-corvette.7643/post-325825
There is a discussion about these small files.
I still use small millers for such a job, but you need experience for that, because it could go easely wrong. I have very small ones and even the circuit board drills could be helpfull. Like I said, experience is needed.
Another cheap solution coould be the use of jigsaw saws.
for such small diameters I use reamer
@Jimsky we had this thema some weeks ago - you mentioned somewhere the correct term for these small tools
They are used for carbuartors
The smallest is 0,33mm I found after a fast research
There are also files for Dentist you can buy, very small ones. On Aliexpress they are very cheap to buy, and we don't need to file teeth but just wood. It seems that these files when they bent, get straight in hot water. Just google and I think they perfect for the job. I got a few in my drawer, the smallest is around 0,4 mm.
Screenshot 2024-04-03 at 12-16-25 3.74€ Dental D Finder Bestanden Roterende Bestanden 8 10 12 ...png
They are called Endo files or K-files, 2 kind of types for use. One like the picture for manually use and also for rotary dentist drill.
example: https://www.premierdentalco.com/product/endo/finger-instruments/k-files/
more Wiki info about these small files
or asked @dockattner he is the teeth specialist around here and maybe he can tell more about it.
View attachment 439517 View attachment 439518
View attachment 439519 View attachment 439520
They only send to a Austria adress …….
If you want a narrow slotting file it is bound to be expensive. However piercing saw blades are cheap and come in many widths. With a short length of one of these held in a pin-vice you can do many things. Here's the blade thickness chart.
And here is a set of widths and a holder -as you see these are not expensive.
why not use jewlers jig saw blades also used for guitar pearl inlay? i have blades that are almost as thin as hair.
make a jig to hold the blade flat like a shooting board and all you have to do is run the block over it.
Unfortunately these are a square profile tools. They are used to enlarge the round holes by inserting them into a hole, rotating and pushing them in. They are not designed for filing. Ones I checked did not even have an abrasive surface - just the bare steel.
yes a bare steel - and a square cross section - I am using them by turning in small holes and the edge is scrapping the hole.
f.e. slightly widing a hole in a wooden block - these are the problems I am using them
BTW: over the length the cross section is getting a little bit wider so you can produce every hole diameter you want and need
- I can really recommend them for such tasks
