Mamoli Black Prince to the "Lady Kathrine" 1:57 Completed
California USA
Since I added my completed model to the completed model section, I thought I would the build log I started in 2012 to it.
Hello my friends,
I have a little time tonight to let you all know that I will be re-doing my Black Prince from Mamoli. I built her per the plans about 13yrs ago. I was not a novice back then. I was the blind leading the blind novice. Well when we built our new home about 10 yrs ago it was never seen again, until now. I found it in my shed. I had thought I had chucked it in the trash years ago.
Right then n there I made it right, because when I did find it I chucked it in the trash can next to my shed. I was going to though some other stuff on top of it that wood of crushed it, but I realized it was my birthday gift given to me from my wife.
I decided right then n there I could not do it. So I pulled it out of the trash can and here we are the both of us. Me n my Black Prince.
Well with the help of Russ n John(Jim Lad) I find out that the Black Prince was a Sloop not a Schooner. With suggestions from Russ I purchased Chapelle's Book Search for Speed. So now I will be converting my Black Prince to a 1812 schooner renamed, but of course...."KATHRINE". my lovely wives name.
Well this is not Sept. or Oct. I was not going to start the re-do of the Black Prince till then. But my spirits have been a little low lately. So I decided to start one of my projects to hopefully perk me up and get on with life.
So i will be using Chapelle's book "The Search for Speed Under Sail". Since so many of these Privateers were built out right or merchants that were converted over to a Privateer. I have been working over Chapter 4 again and again. At this point I still have not decided what sail plan I will be using, but that is still a bit away from that point.
So first I will do the clean up.
Then I will remove the original bulwarks completely. Per the directions all that was needed was two stracks. But it was not enough. The guns did not sit properly at the gunports.
I will re-plank the deck using limewood. Hopefully using the correct trunnel pattern for the era. Using teal oil for the finish.
The bulwarks will be re-built with Sapaley. I will stick with the 4 cannons only. But I will be adding sweeps. I will add the new caprail using scarf-joints.
The color sheme will be flat white below the water line. Flat black above the water line, flat black caprail, and a portion of the inside bulwarks flat black. The rest of the Sapaley will be exposed. Making a few test samples it should look preety good.
As for the furniture the bits will be boxwood. I may be using a combination of gratings and hatches. I will re-build the binnacle. Add bilge pumps. Rig the 1:57 scale cannons. Eliminate the howse holes and go with catheads and timber heads. Re-do the rudder completely. I will also add a trunk cabin and a skylite....
Right now the sails will be partially furled or at full sail. Not sure as of yet. So I will make it my own....
The "lady kathrine"....named for my wife. She only uses one "E".
So let the fun begin.....
G'day teleman
It's a great job, welcome to your first build log on SOS, may this be a start of many more to come.
Happymodeling
Greg
At this point the hull has been painted. After masking the hull off. I painted the hull completely white. Once dried and done with the white color, i masked off the white and painted the portion of the hull that will be black. On the inside of the bulwarks I brush painted a portion black. The rest was left unpainted. I liked the look of the a portion of the sapaley painted and the rest bare. You will also see the finished painted cannons.
you will also notice how you can see the strake lines which i left on purpose for a more authentic look.
i really do not enjoy painting because i do not think i am very good at. plus when the paint is drying i must wait the alloted time for it to dry, which is something i do not much care for. i like modeling at my pace, but in this case the paint is in control of the pace.....
questions and remarks are very much welcomed....
  • Like
Reactions: ADC
Ok on this installment I have reach the making and the installing of the rudder. The installation of the rudder has always been a big pain for me on any boat. You will the original and the new more acurate rudder for my privateer.
Now when I installed the rudder, I decided not to take a drill and drill thru the deck. I built this boat 13yrs ago. I was just not sure if it was going to break thru where I wanted it to...
I also added the sweeps, plus I framed them in...
take care my friends
the next installment....i have now started the construction or bebuild of the ships furniture. A lot of these privateers had a simple companionway to get to the hold. Others wood have a trunk cabin just for the simple reason to provide more head room for the crew.
So since this my personel privateer schooner. i have decoed to add a trunk cabin to privide comfort for my crew members. A total od 12 pictures being added...
  • Like
Reactions: ADC
Ok where did I leave off last night. Well no modeling tonight. Off of work(sorry for that 4-letter word) tonight late. So by the time I get settled in it will be beddy by time. So here's the rest of the pictures.
I wood like opinions on the train tackle blocks. My dilema is I used 2mm double blocks and 1.5mm single blocks. So are they out of scale. I could go to 1.5mm doubles n 1mm singles. drilling holes wood be a bit of a challenge. but going with smaller holes means smaller thread. So wood the blocks be at a better scale????? But now the thread wood be out of scale. HMMMM!
Should I pick what might look best...
I welcome all opinions with great interest...
  • Like
Reactions: ADC
So I have been busy fitting out the deck of my little schooner. Hope you like what you see. Been going over Chapelles Book like crazy. Just having some fun.
Well I can call this one completed. I guess I left off 2yrs ago with a lot of all the accessories left to do. Now just a trip to the glass shop to make the lid and the case is completed. This was the very first model boat I ever did, a gift from my wife.
I accomplished what I started out to do. Mamoli's description that it was Benjamin Franklin Schooner. Well I learned that B.F. had a sloop. So went with a Schooner of 1812, Named it after my wife, tried to get it as correct as possible. With one more challenge was to take a model and re-build it to see if I had the skills to do so. All things considered I think did what i set out to do. Not bad for a model I threw in to the trash can and pulled it out 20 minutes later and decided to re-build it.
I'll add a few more pics in the completed model section.
The workmanship in your build is amazing, Mario.
I only wish I can see and touch it.
As an Ozzie expression goes..... 'It's a bloody ripper.' Please excuse my language, it doesn't sound right if I deleted the b word....:rolleyes::eek:
Havagooday
Grrg
