True story, and dittoThat's an impressive porcupine! Very nice result!
Good afternoon. You make great little ships. Skills! Cheers GrantBeen drilling lots of holes for tree nails. About 1400 to be exact. I first glued the deck to frames. Then I used a .7 mm bit. Thinking I should have used a .6 maybe even a .5. But this is the gun deck. So not to worried about it. I used birch wood toothpicks not bamboo. I made a photo copy of the laser cut deck since the pattern would be lost with 1x5 deck planking. Once the holes were drilled I used waterproof titebond wood glue. I then used zap thin ca from the bottom to really secure them in place. Once the tree nails were cut and sanded I applied some more boiled linseed oil. Since birch wood toothpicks are a little more exspensive I saved the cut offs for my San Bartolome.View attachment 452415View attachment 452416View attachment 452418View attachment 452419View attachment 452423View attachment 452424View attachment 452425View attachment 452426View attachment 452427View attachment 452428View attachment 452430View attachment 452431View attachment 452432View attachment 452433View attachment 452434View attachment 452435
Thank you!I love your precise miniature joinery!![]()
Thank you! Coming from the master that is the ulitimate compliment!!!I have not visited this topic for a long time!
Very good job on the deck!
Is there a reason you did not use bamboo? There is a tutorial that you may find interesting. https://shipsofscale.com/sosforums/threads/making-treenails.14750/Thinking I should have used a .6 maybe even a .5.
Following you on the Ontario is a real treat. I am also working this model, but an earlier version with a different brochure of plans. So I appreciate your posting of the plans as well Your craftsmanship is outstanding Thank youToo hot outside today 104 heat index. So I got to stay in the shipyard with out feeling guilty and the captain telling me what to do in the yard. So I got the first row of spirkitting done. I also made scarf joints for that added bit of realism.View attachment 455212View attachment 455213View attachment 455215View attachment 455216View attachment 455214View attachment 455219View attachment 455220View attachment 455221View attachment 455222View attachment 455223View attachment 455224View attachment 455225View attachment 455226
No doubt, I’ve idolized her and her work from my start , a little over a year ago Learned so much from her videos. But what I’m seeing of your work you can stand tall with the best of them. What a great ride it is…..Thank you! Coming from the master that is the ulitimate compliment!!!
When using birch tooth picks the grain is much tighter than bamboo.Is there a reason you did not use bamboo? There is a tutorial that you may find interesting. https://shipsofscale.com/sosforums/threads/making-treenails.14750/
i have not worked on it in a while. Been concentrating my efforts on the San Bartolome build. Getting really close with that one. I will resume soon though.Hi
Is there sny update on this build?
