Minerva Stern Section 1:48, Da Hai Model by Donfar
OK ALL PUTTING , BAGGING FRAMES AND CHOCKS, READY TO START PUTTING TOGETNER FRAMES BUT NEED SOME DETAILS FROM DA HAI THEN I CAN PROCEED, NOTICE THE CARVED TAFF RAIL DOES THIS BELONG TO VRIAN IF SO EMAIL ME BRIAN WITH ADDRESS AND I WILL SEND IT TO YOU BTW CHINA HAS A VERY, VERY BAD HEAT PROBLEM MAYBE ATTECTING THE PDF INFORMATION ON FRAMES. ALWAYS COMMENTS NEEDED AND WELCOMED. GOD BLESS STAY SAFE ALL DON
Hi Don, it looks like one of your drawings is mislabeled. In post #15 the photo for Frame 21B is labeled Cant Frame 21B but looks like a square frame like 19B. Cant Frame 21B looks right. You should check the plan drawing to see which type of fame 21 is supposed to be. Looking forward to seeing the frames on the keel.
OK I POSTED THIS IN ANOTHER LOG ON THE MINEVA, BOTH BRIANS AND DA HAI, GOING THROUGH ALL THE POSTS AND PICTURES I HAVE SOME THOUGHTS AND QUESTIONS FROM BRIAN AND DA HAI . ON BRIASNS POSTITEM NO14 7/1/2022 SHOWS A FRAME OVER THE FRAME PLAN ALSO PLAN OVER JIG HOW DO YOU ACOMPLISH THIS DO YOU SCREW THROUGH THE PLAN INTO YHE JIG, SORRY DO NOT QUITE UNDERSTAND HOW THAT GOES IF I COULD GET A CLARIFICATION I CAN START ASSEMBLING FRAMES PLEASE LET ME HERE. GOD BLESS STAY SAFE ALL DON
Hi Don, the frame looks good if you stand way back and close one eye. If you are using a cell phone, make sure the camera is steady and the whole frame is in the picture. It looks like the edges are rounded over; at this point they should be sharp. That might be caused by the fuzzy photo.
OKI THANKS TO DA HAI I AM LEARNING TO PUT TOGETHER THE FRAMES ON THE JIG WITCH WILL BE THE BASE OF THE FRAMING JIG. NOTICE ONE THING THESE ARE CNC MACHINED,NO CLEAN UP INVOLVED NONE I REMEMBER SEEING JIMS ALERT AND HOW MUCH CLEAN UP WAS INVOLVED THERE NOT HERE ALL PARTS ARE THIS WAY RIGHT NOW THE HARDEST THING IS FINDING THE HOLES I HAVE AN IDEA BUT IF BRIAN OR DA HAI HAVE A WAY POST IT, ALSO HAVING TO RUN SCREWS INTO JIG HOLES AS SOME ARE TO TIGHT, COMENTS PLEASE BY ALL MEANS, ONLY WAY TO LEARN AS AN ASIDE THE ONLY OTHER PEOPLE WHO DOES THE CNC THIS WAY IS KRIS, AND MIKE SHANKS THANKS TO BOTH. GOD BLESS STAY SAFE ALL DON
OK MORE WORK SAME FRAME, WHAT HAPPENED IS ONE SIDE WAS FITTING GREAT WITHTHE CHOCKS WHEN I TURNED IT OVER TO CHECK UGH, UGH AND MORE UGH GAPS OCCURED WITH BRIAN AND DAQ HELP FOUND OUT THE CHOCKS MAY HAVE BE TURNED OVER RE DID THE FRAME AND IT CAM OUT MUCH BETTER STILL NOT TIGHT BUT A LITTLE WHITE GLUE AND SAWDUST A LITTLE SANDING AND IT IS OK. NOW TO TO GET HELP FROM BRIAN OR DA ON HOW TO DETERMINE THE CORRECT PLACEMENT OF THE CHOCKS. GOD BLESS STAY SAFE YOU AND YOURS DON
From the picture shown when the frame was first assembled, there appears to be a gap, so it's not too surprising there was a larger one when reversed (although it's tough to tell with the blurry pictures). I think I've read elsewhere that the major main frames pieces are to be assembled tight (no gap), and once properly in place, the chocks are to then be inserted. Further, that the chocks are oversize and will definitely require trimming or sanding after assembly. Before placement, too, if they don't fit properly. It's certainly good to get a technique going for the work, since there will be many more. :-)
