Amazing work, DD. Could you simply swap the legs without cutting anything? If you must cut the claws off, then a sharp knife should be adequate for cutting through hot melt glue. Multiple shallow passes should get you through cleanly.View attachment 550040
Got one foot left then I can get to thickening. Picked up a can of spray paint to help the crepe paper go farther.
View attachment 550041View attachment 550042
Decided to leave the gaps as it's just going to be covered
Only problem is a put the dew claw on the same side. Any suggestions for cutting it off and swapping sides? I have a foam cutter thingy kit to get through the hot glue maybe but not sure if it would ruin it / how to clean it..
