monitor model
toma
New Member
hello everone,
i/m a neophye boat modelet and have built a few bluejacket solid hull boats. i'm hoping to build a frame on plank boat next. i did have one question. i am working on a monitor model. i was wondering the best way to score the deck armor. i was having trouble with cutting acrosss the grain without leaving a frayed edge. many thanks.
tom anderson
Jimsky
Moderator
Moderator
Brooklyn, New York USA
First and foremost welcome to the SOS family! We are glad you found us! Please enjoy! if you don't mind, we would love to see your work, and it would even better if you start your own build log ;) You can start your own build log here (see the link below), choose what is more appropriate for your build.
As for your question, one way to cut across the grain without leaving a frayed edge is to tape surface with painter scotch tape, then cut. Use the saw with small teeth.
I hope this ill help.
SAHaskell
Well-Known Member
United States
Greetings, toma. Depending on the size of the desired cut, a feather-edge file might work for the job.
Good luck and Happy modeling. :)
Uwek
Admin
Administrative
Blandford Group Build
Vienna, Austria
Welcome also from my side here on board of our forum.
Uwek
Admin
Administrative
Vienna, Austria
Hallo Tom,
