Happy belated Xmas & new year from down under.
I have now completed all the individual parts ( minus oars & masts). The items all have to be completed form either wood strips or in the case of the rudder cut & filed to shape from a generic ply piece. The wood strips were phtotcopied plans white glued to strips ( The paper washes off in water after cutting & drilling where needed.0
I completed each of the parts in random order ( personal preference / time needed to do). The only items that need to be done out of numeric order( but together) are the rudder & Hull modifications. ( there is another dependant on display status - will get to later).
None of the parts were difficult to assemble and the plans clearly show how they go together. ( The only hard part was identifying the wood used ( Not in english) , and some of the smaller brass pins.
The rudder consists of 9 parts (Rudder Template(ply), 2 brass pins, 2 brass eyelets, 4 x 4 & 5 x 5 wood blocks ( precut in bag), copper bands and ship hull .
The rudder needs to be shaped ( u bend) & pin placing cut out. The same cutout also needs to be done on hull . To position these correctly, lay the rudder on the 1:1 plan on plan sheet 2 & mark both positions on the rudder. The lower can then be transferred to the hull & cut. ( this is after you have nicely glued capping & veneer on to hull in previous instructions! All screw hoops / eyelets provided are NOT screw based in my kit but just normal kit brass eyelets( drill & glue)
The furniture & other items do not all have to be done, It will be dependent on how you want to display the kit. Ie Oars no sail, oars & sail furled & masts laying on supports internally or Sail/Mast up, no oars. I've still not decided on the layout. As all those options including tiller are pinned & removeable it does not matter when you do them.
The ones I have completed ( Raw) are shown below. These are the Capstan ( cardved from one 10x10 Walnut strip), 4 Capstan handles ( ends yet to be shaped smooth, Axe ( brass head, handle shaped from 4mm dowel, polearm ( brass head pole from 4mm dowel). Chest/ lid & rope coil( not 14 coils of rope as per instrructions , but one cole with 14 winds) and rucksack.
Brass lantern & brass compass on wood base. Floor access panels, Water barrel ( cork from 4mm dowel), Barrel stand , Launch
& rope bucket, Rum Barrel internal ring & hook assemblies. ( Barrel rings to be painted & cork to be topped with blue
Rudder( With pin block & eyelet installed, Tiller & Ships anchor Davit assembly( Pins to be cut after final fitting to hull).
Last be not least the rope buckets & laying mast supports. The Rope bucket was fiddly but I used glued 6 staves per break instead of 3 per break as suggested. With 6 the break was a 'V' shape the width one stave at the top. In this way final staves were just staves cut diagonally such that one stave fitted 2 breaks and in the final completetion it was not obvious due due the external lashing. Internal ropes were all glued & soaked with 50/50 white PVA / Water. This dried clear and matt.
None of the fittings were overly difficult and can be done with no power tools ( except I cheated with scroll saw for plan cutouts).
Next will come the the fitting of seats and attachment of mast supports, Capstan and Ship anchor management ropes ( holes to be drilled into bottom of hull for same. ( Longboats were also used to lift / place ships anchors if needed). The hull will definitely need to be painted externally prior to rope fitting.
See you in the next installment.
