Ipurchased the Ultimation tool and really love it. Not cheap, but well built. Easier to manipulate without scraching nail or skin and more space to visualized what we are doing.
I have that tool. I purchased it from Sunward Hobbies in Ontario:Hi, is the RP Toolz Mitre Cutter worth it ? The original set is from Poland seller and cost 107 $Euro (or 155 $CAD shipping included and EBay sell it at 161 $CAD plus shipping from australia. A lot of money for a small tool. But ist really better than the oll Chopper II from NWSL ?
Thanks to inform me.
Michel
www.sunwardhobbies.ca
What a great find with the little cutoff saw. I Just ordered 1 off eBay. AU$48 delivered with extra blades. Cheaper than most the"chop" styles which I had reservations about. I'll build a similar extension base. Thanks for sharing!!All that being said, none of the "chop" type cutters cut with a perfectly strait cut end. They all leave a bit of a taper and require sanding to truly square the cut end up, although I think the RP does the best job for me.
I finally bought a mini chop saw or as some call them, a mini power mitre box. Proxxon makes a very nice one, but the price was out of my range. I got the one from harbor freight, with 2 packs of extra blades for about $50.00. It cuts great, with very square cuts. I made an extended base and a fence for it as most of my cuts are strips. Cuts up to 1/2" X 3/8" stock, hard and soft wood. With a cutoff disk it will cut metals as well.
EJ
Following your lead I’ve obtained one of these and made my own modifications. Really pleased with the result. Cuts very accurately, can set up fixed lengths easy and do angles using a block I insert. Not bad for less than AU$50 and an hour of mucking around. Can be returned original clamp very quickly but I found the clamp thing a bit finicky to use and I couldn’t get consistent 90 degree cuts.I have used several different "chop" type cutters, including the RP. Of them all, the RP is by far better constructed. All aluminum, has some weight to it, the cutting arm has a great bearing surface so it does not wobble at all, Very nice mitre gauges and a stop. It uses a single edge razor blade, but without the "handle" on one edge like a standard blade. Has an inlaid cutting mat in the cutting area of the table.
Some of the others I had have a rather poor bearing for the cutting arm. One I had to replace the particle board base because the groove where the blade hit it got so big the cut parts splintered on the back.
EJ
