I am not 100% sure, if I understand your question correctly - are you asking about the used unit of length?Uwe, these monographs published in English, what type of goal do they have ?, cm / mm ?. greeting-
Uwe
I will post some pics,as I need to check all the Drawings are there,I am worried I have two copies of sheet 5.I am seriously thinking of starting a log.There is a serious amount of considerations to think about before making dust.To discuss these may be a valuable resource for other builders.Every true plank on frame build log I have seen immediately starts with keel or frame assembly and seems to skip the preparation bit.
Biggest thing with this build seems to be the typical French 'sistered' frame design is different in that the sections are mortice and tenoned together as well as bolted.This changes everything as I have not seen a model build that has this design and from what I have read so far appears to be unique to Coulomb.
Kind Regards
Nigel
