Santisima Trinidad [COMPLETED BUILD]
Your ratlines are looking good - you are using the correct knot "clove hitch".
But I realized, that on e the right end at the last shroud you made also the same knot,
but on the left side it is looking like only a single loop around the shroud ?
Can it be that you started from left to right with only a loop?
Yes, all correct, but they are not glued, at the bottom there's already a couple I replaced with the correct knot
I found it hard to do on the 1st when no end is attached
