HI I AM ONE OF THE FORTUNATE ONES WH CAN NOT ACCES MSW BUT I DO LIKE THIS ONE MUCH, IS THERE A JIG FOR THE FRAMES AND IS THERE A SOS LOG ON THIS IF SO IS THERE A LINK. GOD BLESS STAY SAFE ALL DON
Maybe... if USPS can actually deliver it!
I read that as well, but no, at this scale it hard to follow the exact method. The Mortise and tenon joints would be interesting to build in a bigger version.On 6/13/2021 at 6:03 PM, Chuck Seiler said:
Lyle,
The Excavations of an Ancient Boat from the Sea of Galilee by Shelly Wachsmann (hereafter known as Wachsmann-Excavations) shows the planks have diagonal butt joints. Will you be modeling that into your build...or leave well enough alone?
Are you thinking plank to plank seam?On 6/13/2021 at 7:10 PM, Chuck Seiler said:
You are making great progress.
Uhhgggg! No, not the actual mortise/tenon joints themselves. That would be some chore. I was thinking more the line of the actual joint.
Gotcha!On 6/13/2021 at 9:39 PM, Chuck Seiler said:
No, I am talking about the joints plank-to-plank along the same strake. Attached is an example, but with far too many joints. Figure 5.12 and Foldout 1 of Waschmann show these, but hard to see.
I started at 10-15 minutes... and on the last plank it was closer to an hour.
They used a technique called mortise and tenon to join the planks.On 6/22/2021 at 6:16 AM, Snug Harbor Johnny said:
I read an article on the 'Jesus boat' recovered in Galiliee ... is this the same boat as the one in this thread? The boat in the article in Biblical Archeology Review showed the the strakes were composed of many oddly shaped planks (some of them short) that were fastened together with lashings passed through severely made holes in the plank edges where they abut. The whole thing looked like a big 'jigsaw puzzle'. The article suggested that valuable wood resourced back them was used with a minimum of waste ... it reminded me of some Inca stonework where all the oddly shaped blocks were fit together so as to remove a minimum amount of material, yet be snug against each other. Johnny
The “ribs” are the next step after some sanding.On 6/28/2021 at 8:18 AM, Snug Harbor Johnny said:
Now I can see how the planking was done ... so whatever goes inside rib-wise or thwart-wise is an installation process - plus whatever else in the way of oars, mast, rigging, etc. Very nice! I'd like to 'improve' (bust?) the ship's boats of the Endurance (actually I'll build them first as practice), since we have exact measurements on three of them (the fourth was the same as Schakleton's lifeboat) and many photographs. There was a recent post on improving ship's boats for HMS Victory, where the assembly ribs were removed and replaced by more scale-like boat ribs - along with thin footlings, scale gunwale (with grain going in the right direction) and a variety of accouterments on hand in such boats. Each boat also has a graceful upward curve to the stem and stern (not sure of the correct term) - and that might be done best by installing the plank below the gunwale first to establish the curve - them go on planking downward (tapering planks as needed). Taking the time to do a better job on details such as these will greatly add to the appearance of the model as a whole. Johnny
Expand
so·lid·i·tyOn 6/28/2021 at 11:17 AM, Chuck Seiler said:
Lyle,
How structurally sound is that? Will the frames beef it up or re they just for show...and it requires the thwarts for solidity (is that a word?)
Hmmmm... even CA glue?On 7/7/2021 at 11:11 AM, TOM G said:
Use a peice of saran wrap on your spacer....... glue won't stick.
I presume you are referring to the ribs?On 7/7/2021 at 2:46 AM, Louie da fly said:
Nice. Are you intending to double up the frames so they overlap each other?
On 6/11/2021 at 4:56 AM, Louie da fly said:
Though the lateen is now known to have been developed earlier than previously thought - as evidenced by this tombstone, dated to the second century AD
this is the only evidence for such prior to the 5th century; all other contemporary representations I'm aware of show square sails. So a square sail is far more likely for the Sea of Galilee ship, which is dated to the first century AD. Indeed, i have seen both typrs depicted on both Egyptian and Phoenician boats of the general era.
Expand
It stands to reason that there existed both lateen and square sails in the Meditteranean Sea at the time. Indeed, I have seen dipictians of both Egyptian and Phoenician boats.
On 7/7/2021 at 11:25 AM, LyleK1 said:
The pattern shown is followed throughout the hull. Based on the original, that appears to be the correct pattern.
I don't know about ca glue....... I use WELD BOND...... I have had bad results with ca glue....... comes apart in time........ Maybe it was the brand of glue I used ?
I use Bob Smith Industries... works well and we'll see about the longevity.On 7/8/2021 at 7:58 AM, TOM G said:
Yeah… I wasn’t liking the look of it either and I have altered it:On 7/18/2021 at 4:13 PM, Chuck Seiler said:
Wow! Significant progress. Looking good. I find the cutwater very interesting. It seems quite large for such a small boat. I guess you might need it to ram rival fishermen.
Thanks Chuck! I’m pleased with look of the model.On 7/18/2021 at 8:10 PM, Chuck Seiler said:
Lyle,
That is really looking good. You are well on track to be done on time. I hope mine ends up looking as good as yours.
Thanks Steven.
Thanks Moab!
Interesting that the book I read did not mention floor boards.On 7/24/2021 at 9:49 AM, Chuck Seiler said:
Lyle,
Looking good. I like the finish.
The excavation report indicates that there may have been floor boards/deck boards as you have modeled. Floor boards were not found with the wreck, but this is easily explained since they would have been salvaged before the boat was abandoned.
Expand
Excellent idea! Will give it a try!On 7/27/2021 at 7:08 AM, Estoy_Listo said:
A small travel garment steamer might be useful. They work well in removing folds and wrinkles from clothing. Just pass the steam over the fabric. Don't hold it in place for too long. Those things are hot.
I don't think so. My dad has limited space and this guy should be pretty easy to keep clean!
Thanks Bluebeard!GREAT!!!!!!!
Your building log for sure is more detailed than my.
Congratulations on your great build.
