Maybe because you first posted this topic in the area of "Tutorials of How to use this forum". I guess 99% of the members are not looking at this area, only when they have problems with using the forum......What am I doing wrong? I have posted a question and nobody replied. This is not normal for this group.
I did not realize my error. Thank you for moving it. Thanks to all who responded. Jimsky has given me a users guide by Badger so I can understand what I am reading.Maybe because you first posted this topic in the area of "Tutorials of How to use this forum". I guess 99% of the members are not looking at this area, only when they have problems with using the forum......
When I realized it, I moved it to the general area (I sent you this info) where much more members are reading a new topic.......
Therefore the reaction time for response was much shorter......
Hi Bob, in post #3 above Jim provided a link to a two page discussion on some aspects of airbrushing, people’s preferences etc. If you scroll back to the beginning of the first page of that thread there may be some useful information in the responses that follow.I need tutorials on spray painting wood models. Also recommend basic sprayer and paints. Thanks. I have tried to search here, but not having much luck. I must be doing something wrong.
If you search YouTube for "spray paint wood ship model" you'll get a lot of hits. https://www.youtube.com/results?search_query=spray+paint+wood+ship+modelI need tutorials on spray painting wood models. Also recommend basic sprayer and paints. Thanks. I have tried to search here, but not having much luck. I must be doing something wrong.
I always use dedicated acrylic paint thinners & a Badger airbrush. But I've not used it on a ship model yet, since giving up model railroading. Rattle cans are more convenient, I find, as sanding sealer & matte clear coat are both available. For primer spray I use Tamiya or Simonize aerosols.One thing i recently learned about airbrushes is that the tip can clog very easily if you use too thick a paint, such as some acrylic paints. So, what I did is I tried to dilute the paint with water. Not a good idea, I found. The paint did no longer stick and I made a mess. Not sure if this was because I didn't dilute properly or what. I then read over some posts on this site, and found a recipe for paint thinner for airbrushes. I have yet to try this because I am in the process of moving, but here is the recipe anyways, in case you decide to use an airbrush in your endeavors. If you don't mind, pls let me know how things go on your end and if you try this method, what your results were
Recipe:
Acrylic Thinner Mixture Procedure
Distilled water 38 ml
91% isopropyl alcohol 22 ml
Flow-aid 1 ml (Liquitex)
Fluid retarder 1 ml (Golden Retarder)
25 psi on compressor
Mixing Proportions
1 part acrylic paint
1 part thinner mix
Note: some acrylic paints are designed specifically for air brushes. My problem is that I need a large amount of paint due to the fact that I am building a 50 inch long Bismarck model.
Hallo @Bobc622I need tutorials on spray painting wood models. Also recommend basic sprayer and paints. Thanks. I have tried to search here, but not having much luck. I must be doing something wrong.
