St. Caterina by Schrader – Small Ship - 1/12 Monography by Franco Fissore - Plans by Ancre
MEDELLLIN-COLOMBIA
My New project is the St Caterina. It is a Mediterranean fishing vessel. Plans from Ancre. I started it since October and is well advance so far.
  1. I decided this time to go after a old fashion diorama
  2. New tech to aging wood (At least for me)
  3. New tech for nails (Also at least for me)
Please don't hesitate to make comments
Hallo Helmuth,
a great project and I will follow with big interest - please check the photo(s) - they are not working.
Would be great if you would edit your post.....
Aging.....
Once the planking is done I proceeded applying danish oil......
Then with a drill wire brush I went to mark the wood as it was a real weathering or attrition.....
Then..... with cement grout (not that liquid) I proceeded to “paint” the hull. Wait until it is almost dry. Make sure that the grout is going to all the scratches you made with the wire brush
The with a cloth or kitchen towel take the grout surplus.... The result should be lake this...
The nailing has been done with sewing pins.
To the main hull, I cut them. Flat them with a sander belt and blue them. Also I decided to tape the hull in order to protect it. As a drill bit I used one of those pins, it worked really well, and the hole was perfect to ensure the pins.
MORE THAN 1000 PINS WERE NEEDED!!
4B0DFC8D-A558-4CEA-ADCD-A500208F59C4.jpegAC0AA825-B936-45BF-B953-A3BD43756A23.jpeg6D420926-3F4A-4955-986C-093439AF576B.jpeg8CFCC004-F0BB-4C0C-B6B8-7230DD80CE2C.jpeg
Very good treenailing job!! Some of them are with the square heads, on the gunwales? What technique do you use?
Today I’ll show you the process I used to build the benches.
First, I cut the templates
With the belt sander and router, I finished all of them but the middle one, which has this middle circle, where the mast will located
For this particular bench, in order to make sure the half circle will be perfect, I used doble side tape, I taped a piece of wood (with the same thickness) beside it.....
I drilled the hole.....
