St. Caterina by Schrader – Small Ship - 1/12 Monography by Franco Fissore - Plans by Ancre
Thanks a lot Uwek!!!!
Anchor grapnel.......
This piece has some difficulty since we have to weld 8 pieces in a little space. Producing heat that will pump out those pieces that are already welded. So I decided to make a “mold” where all pieces can be “secured” ....... Two pieces of wood with 5 holes.... 1 for the central piece and 4 for the hooks
One 2 mm wire heated in one of its ends...
Smashed......
its hole...
A little tube in the other end and hooks in 1 mm wire....
To the mold and welded......
So far so good......
The tips....
And.....
Aged.... It is done...
That is a great scratch build. Looks like some of fishing lures my wife used on big fish!, but of course hers are not finished the same as yours.
Base.....
I decided at this time, it will be my first diorama. So I went to the internet and the monograph and I saw a couple a good ideas. I went to prepare de basa as a beach with sand, taking care of the leveling, not uniform surfaces and so......
I put some logs...aged. They are going to “receive“ the boat....
Let’s see how is looking so far.....
I t need to be completed with some “fences” and fixing some spots without sand.....
now.... let’s start to see how is going to look forward.... but before we need to work in the beach capstan ....
Great diorama and model - Looking very good.
I think the boat laying on the slipway is a very good way to present it
Uwek
Thanks a lot. I was thinking about putting a couple of wedges to show the boat vertical..... your opinion?
Regards
I am not sure, if the fishermen would have done it - to bring her vertical
- with this inclined you have a maybe better view inside the model
but this is maybe mainly a question of taste
If you have not done so, I suggest you secure your sand to the diorama base.
I also do model railroads and we always secure scenery material to base.
If you need to, prep how you want it, then give light coat of "wet water" water mixed with soap to allow it to soak in, then apply diluted matt medium or white glue to soak and when it dries you should not be able to tell its there. Keep sand in place if the diorama gets bumped or items get nudged.
I did it but I did not know about using soap...... what is the reason behind?
Adding soap or isopropyl alcohol to water helps break down surface tension on material. This allows glue to later soak down into scenery materials better. If not fully wetted before the glue just makes a crust on top of material, and if thick it will still be loose underneath, and then if crust on top is broken the loose material goes everywhere. Just ask me how I know this fact!!
With trains, we have what is called ballast on sides and underneath tracks, which can be 1/4" thick in scale I use. My first attempts to glue down worked what I thought was well, then in use the crust cracked and loose bits of gravel when everywhere.
Just like other on this forum help us newer folks to learn ship building, my fellow model railroaders told me what I did wrong and how to fix it.
Thanks a lot !!!!
This is going to be my previous last post........ The model is “already finished”......You never finish a diorama.... you have to abandon it!!!!
The beach capstan usually were anchored to a stone wall. This was necessary to provide resistance at the time they pull the boat to the beach.......
I used “nativity” technique to create it....
