That's what a real craftsmanship is all about!!! Excellent!!
grapnel.......
Thanks Jim.... just following your stepsThat's what a real craftsmanship is all about!!! Excellent!!
I am not sure, if the fishermen would have done it - to bring her verticalUwek
Thanks a lot. I was thinking about putting a couple of wedges to show the boat vertical..... your opinion?
Regards
If you have not done so, I suggest you secure your sand to the diorama base.
I also do model railroads and we always secure scenery material to base.
If you need to, prep how you want it, then give light coat of "wet water" water mixed with soap to allow it to soak in, then apply diluted matt medium or white glue to soak and when it dries you should not be able to tell its there. Keep sand in place if the diorama gets bumped or items get nudged.
Adding soap or isopropyl alcohol to water helps break down surface tension on material. This allows glue to later soak down into scenery materials better. If not fully wetted before the glue just makes a crust on top of material, and if thick it will still be loose underneath, and then if crust on top is broken the loose material goes everywhere. Just ask me how I know this fact!!
With trains, we have what is called ballast on sides and underneath tracks, which can be 1/4" thick in scale I use. My first attempts to glue down worked what I thought was well, then in use the crust cracked and loose bits of gravel when everywhere.
Just like other on this forum help us newer folks to learn ship building, my fellow model railroaders told me what I did wrong and how to fix it.
