Tartana de Liguria, scale 1:200
I have started the construction of a new model to add to my collection, which will be number 67.
It is a tartana from Liguria in a scale of 1: 200. I use as a main source of documentation the monograph of the tartana Gemma, by Franco Fissore, published in Ancre, although I will also use other complementary sources, such as the book "Vele italiane de la costa occidentale" by Sergio Bellabarba and Eduardo Guerrieri, and old photographs of complementary form.
For the construction of the hull use Finnish plywood of 0.6 mm. to make the frames.A6DFD18D-D9F4-4A02-A2EA-8BFD09C1D671.jpeg2F23509F-15EE-4227-AAFD-BA70C9170FE3.jpeg1BABC5F5-8B63-4D33-8D72-2079DAB97DA6.jpeg2415D78A-AC34-4545-81F6-0B3001EAC9BD.jpeg29429DB4-48D8-4F47-A9DD-29E8F3E4402D.jpeg834C6EBC-E262-41E9-841F-6A8B822C096C.jpegA6928514-2445-4A96-88F3-2CAC6D33CF42.jpeg
Mike41
Forum Moderator
Hi Javier, great start on an interesting model.
Mike
A lot of thanks for your comments. On this weekend I closed the hull. As the model is going to be painted, I have not taken too much care of the placement of the strakes, which I would have done if the hull were in exposed wood or in a clinker built instead of a carvel built.
Then I have sanded and polished the hull before proceeding, as next step, to tear out the false frames. To harden the hull before its sanding I have covered it, as if it were a topcoat varnish, with a layer of liquid cyanoacrylate.
3038F5A1-42D3-4C1C-8D24-0460778526EE.jpeg73CAA85B-4C58-4C9B-A7BE-01B587439D2E.jpeg716189ED-BF90-42E9-8565-BF341CB9DDEC.jpeg
For the construction of the hull use Finnish plywood of 0.6 mm. to make the frames.View attachment 63399View attachment 63400View attachment 63401View attachment 63402View attachment 63403View attachment 63404View attachment 63405
Hwat a great vay to trasfer the dravings to bulkheads , kiel, bouv and stern.
i vil follow Your prosjekt, very interestig smal bild.
Greatins from norway.Thumbsup
Uwek
Administrator
Administrator
Vienna, Austria
The covers of the hatches and the cabin of the camera are removable to be able to see the interior
and I am happy, if I am able to make this in scale 1:48 !!! - it is really extreme what you are able to do in this small scale - Great work
