Great job on the dales. I particularly like the reinforcing bands!
Yellow heart is brittle, but it can be bent. Use thin planks and take care.
The blade with my Proxon FET saw when delivered was a rip saw blade. You can get. and I had ordered, a finer toothed cross cut blade which works better but I would like one finer than that but only a diamond type of "grinding through" blade is offered and I don't want to burn my way through wood. Hardness of the wood is also a problem when trying to do sharply cut pieces I have discovered. Rich (PT-2)Hello Eric, I don't own the Proxxon Fet tablesaw, What is the arbor size 10mm or 12mm?
What do you mean by finer Rich? More and smaller teeth? If so have a look at NO 28 730 for instance. That blade has 250 very small teeth.The blade with my Proxon FET saw when delivered was a rip saw blade. You can get. and I had ordered, a finer toothed cross cut blade which works better but I would like one finer than that but only a diamond type of "grinding through" blade is offered and I don't want to burn my way through wood. Hardness of the wood is also a problem when trying to do sharply cut pieces I have discovered. Rich (PT-2)
How many gallons will that long baby deliver? Rich (PT-2)First "draft" of the elm tree pump...View attachment 196558View attachment 196559View attachment 196560
Dave ( @DocBlake ) is all about the reinforcing bands lately.Nice work on the elm tree pump. How did you do the reinforcing bands?
Paper or whatever it needs to get the job done and your path was very well carried out. Excellent. Rich (PT-2)Dave is all about the reinforcing bands lately.
I used a razor blade to cut very thin strips of dark, heavyweight, paper. (Paper was a very dark grey color). I blocked this with a ruler to get as thin, but and even strip as I could. Very light PVA glue on the back side and wrapped the strip around the pump. Sometimes it takes a couple of attempts to get the wraparound to match up perfectly, especially if the cut isn't perfectly even, but it's not hard at all, and I really like the look.
