Threading Rigging through the blocks
Maybe the below will be helpful. There are no holes in a real block, but rather, for a single block there is one slot for the sheave and it is located so the line can pass over the sheave. As Roger explains, at our most common scales, a single hole is usually fine as the rigged line would block out a view of the opening between the tail piece and sheave. Just be sure the hole is at the crown end. A lot of build logs show the blocks upside down with the hole between the would-be tail piece and sheave rather than under the crown and over the sheave which would not work.
"Just be sure the hole is at the crown end" - thanks for this comment, it is really important
FWIW, I've used needle threaders for decades, and I've only experienced breakage of one or two small blocks in all that time. I even purchased a set or rigging tools... which were basically 30cm (one foot) long wooden dowels with various metal tips glued into the ends of them. Many were darning needles that had the eyes cut or reshaped under heat to provide a variety of hooking and grabbing tips... but one of them was basically the thin wire from a needle threader epoxied into a hole drilled into the end of a dowel. I use the clamping hemostats as well, but for a slightly different purpose. I may use them to lightly hold a block steady as I'm running a line through it, but what I use them for quite frequently is to provide a weight to the end of a line that's been run through a block to keep light tension on it while I'm getting ready to run the end of that line through another block or fitting.
I really like the looks of what you've completed so far... really nice, so suffice it to say, "keep up the good work!".
Hi Seadeep, Any chance you could provide a photo of what you describe in your post please as I think I could benefit from your method.
A YouTube link for the newbies among you, me included on how to make off a tiny block. You need three hands as it’s such a fiddly job and this method is really good.
Hope it helps
