- Feb 23, 2019
I haven't got enough space so I'll be giving it a miss.Looking good Peter.
I bet you have an eye on the new 1/200 Sharnhorst just released.
Hallo @PeterairfixI will change the title thread I you can guess the ship by the only clue I will give and it should be easy if you know your ships
she's almost finished i just have to do the masts and rigging but this is going to be the Olympic but i was unable to change the titleHow is the work on the Titanic going on?
I have started on the planking so I will be at it for a couple of weeks View attachment 203584View attachment 203585
Hi, Peter. I'm building this model. I bought it built to issue 21 and noticed I'm missing the rudder support and rudder from issues 12 and 13. Is there a way to make my own?I have started on the planking so I will be at it for a couple of weeks View attachment 203584View attachment 203585
I have built a couple of scratch build titanic if you have the empty frames you could use them as templates either using wood or I found it easier to use plasticardHi, Peter. I'm building this model. I bought it built to issue 21 and noticed I'm missing the rudder support and rudder from issues 12 and 13. Is there a way to make my own?
Hi, Peter, thanks for your response. The thing is, I need scale plans of the missing parts so I can fashion them from spare wood.I have built a couple of scratch build titanic if you have the empty frames you could use them as templates either using wood or I found it easier to use plasticard
Do you have issue 64 as it contains a large 1/1 plan if not there are a couple on ebayHi, Peter, thanks for your response. The thing is, I need scale plans of the missing parts so I can fashion them from spare wood.
Regards Graham
