Triumph Tr6, 3d printed large scale
Thank you russf. Yes the tr6 con rods are angled. You actually researded it more than I did. The cast effect is a mix of both print process and a not very good paint job. But I do like the effect! As for the tapped holes, I printed the basic hole ( tap drill sized hole), in most cases .040" dia for a 00-90 bolt and tap the holes after curing.
A few more pictures
View attachment 20251230_203229.mp4
Another amazing aspect of your models is the apparent short time between design and production. It's really a pleasure to follow your work François.
So the head is painted with a little bit of oil weathering added.
I had a plan all laid out for the valves but as is often the case, my plans don't always work. My intention was to "machine" a groove in the valve stem to receive a circlip but since I don't have a lathe, it was very difficult to make the grooves identical and at the same place on all 12 valve stems.
Circlip groove
First valve set
A few valves with the circlip installed
I need to have all the stems as equal as possible so the rockers align properly. So I ended up removing the circlips which was used to hold the valve spring and replaced them with a flat headed pin which is inserted and glued in the valve stem. I did a test to see if this new arrangement worked before doing 12 new valves. It worked great!
New valve design test
View attachment 20260104_194948.mp4
All 12 new valves installed
Viewed from under
View attachment 20260104_215502.mp4
Head on bloc with oil dipstick in place
