USS Coates DE-685
  • Thread starter Thread starter NTIB
  • Watchers Watchers 9
USS Coates DE-685 building progress. Underwater jewelry in place. The screws to me are a part of history. They were made for me by CDR. John Woodward USN at the Longbeach Naval Shipyard. He was in charge of the Propeller Shop, and made lost wax castings, using a scrap piece of manganese bronze. The bronze came from a propeller off a WWll Fletcher class destroyer being scrapped. I do not know which one it was but the history, oceans, possible battles, where these propellers may have been,,,,,
Very nice! How did you make the hull? Do you have a docking plan for those drydock blocks? Don’t want o break her back!
Roger
Roger
Thank you, I made a plank on frame hull from ship's plans. At the same time a friend was starting to do the same for a business. Making a plug then a one piece fiberglass hull from that. The decking I made from 1/8" styrene and sealed it with Dupont Corvette body filler that would not shrink. The Keel blocks were made from Cherry wood and arranged by the ships docking plan. I used 3 machine screws through the base mating with machine nuts secured in the hull. This makes a secure mount and can be removed if required.
The construction rate is impressive, given this good quality. Thumbsup
I wonder how similar the Rudderow class is in detail to the Buckley class and the John C. Butler class?
The construction rate was years with many breaks in between. The Rudderow class uses the same hull as the Buckley & JC Butler class. The structures above deck are very different on Buckley, and only similar to Butler. My circa is early to mid 60's
