Thank you.A very clever solution Mustafa!
Great work I always learn a lot from your build. I wish I had a milling machine.I created the square holes that the capstan bars are inserted. I used my milling machine for making them.View attachment 426238View attachment 426239View attachment 426240View attachment 426241View attachment 426242View attachment 426243View attachment 426244
Many thanks for the comments and likes my friends.Great work I always learn a lot from your build. I wish I had a milling machine.
Indeed!nice problem solving Mustafa
Your pumps look great.I first made the frames from wood because I didn't have square brass bar. But I didn't like it very much, it was too rough and far from reality. That's why I remade them from brass wire. I think they look more realistic now.
View attachment 427132View attachment 427133View attachment 427134View attachment 427135
Thank you so much.Your pumps look great.
Are you going to try to add outflow pipes? (Picture from the Cross Section model)I tested with the beads I found at home to see how the pump would look when the pieces are put together. I am pleased with the look and hoping the pump will look better once it's painted. I will try to find smaller spherical beads.
View attachment 427491View attachment 427492View attachment 427493View attachment 427494
Yes, I will add those pipes once I find the appropriate size beads. I used the beads in the photos just for testing.Are you going to try to add outflow pipes? (Picture from the Cross Section model)View attachment 427499
