How FUN is this exchange! Congratulations, Waldemar, for a significant contribution, and to you, Fred, for the discussion and engagement! Just great stuff!
Vasa is the length it was intended to be, within a meter or so. It is also the height it was intended to be from the earliest design discussions, the major change from specification is in breadth.
Was there an initial limitation for the drаught that could not have been exceeded?
There was no operational requirement that limited draught, the navigable water in the ship's operational area had plenty of depth to allow a deeper hull. Relatively speaking, Dutch designs of the 17th century have shallower draught than English or French designs of the same displacement, which is related to local conditions in the Low Countries. Dutch designers working in Scandinavia continued to build shallow draught ships, no doubt because these were the hull forms they knew.Does the height in this context includes the depth of the hull underwater? Was there an initial limitation for the drаught that could not have been exceeded?
I would really like to avoid using the term verlanger here, as it has a specific meaning in 17th-century terms that does not apply to Vasa. However, the basic idea of a design that was reworked while the ship was being built is entirely appropriate. The significant changes that can be observed in the ship itself are the increase in width over the contract specification, the lengthening of the sterncastle decks and cabins, and the relocation of the mizzenmast. The extension of the sternpost may be a design change, although it could be result of a timber that was too short, although there are associated changes in the deck structure that suggest that this is a design alteration. We do know that Vasa's sister, Äpplet, is about 1 meter wider overall than Vasa and has a higher sterncastle, so the increase in stern height may well be a design alteration. There is no indication of an increase in height at the bow, there is no extension of the stem..Thank you very much, Fred, for all the detailed information about the hull shape. As it is not possible to verify all possible variants in one "deal", so I will most likely nevertheless check the verlanger option first, but not in the classic scenario, i.e. the reworking of an already completely built hull, but rather of the variety of a dramatic change of the design concept already after the start of construction at some stage, with the building material already prepared for the original variant, as you write about it. The inappropriate, too-low run of the line of greatest breadth symmetrically on both sides, the extended stem post, the extended stern post and perhaps something else, is already a number of indications that can hardly be easily ignored (for greater clarity: it's for the assumption that Vasa is a reworked still during construction of a smaller ship of the whole, complete contract, if I remember the circumstances correctly).
However, I am away from home for a few more days and do not have access to all the material I should be consulting while making this attempt. I apologise for this delay.
It may even be possible to write a doctoral dissertation on the subject, but in practical terms it is probably the shortest way to say that a ship of 'similar' size (and sporting tumblehome) should not be submerged more than two-three feet below the line of greatest breadth (admittedly, one of the royal French ordinances of the second half of the 17th century provided for an equalisation of these levels, but it is not entirely clear whether this should be interpreted quite literally, and even less whether the designers complied with this ordinance in such a literal way at all, especially as they must have been aware of its potentially very dangerous consequences).
It started as a dog, and attempts to improve it just made it a fatter dog.
Length between posts | Keel length | breadth | depth | Stempost rake | Thickness of floor timbers | |
Fides 1613 | 124 | 90 | 30 | 11 | 30 | 12 inches |
Hummeren 1623 | 107 | 80 | 26 | 6 | 23 | 11 inches |
König David 1625 (measured) | 120 | 26 | 14 | |||
Göteborg small design 1631 | 120 | 91 | 27 | 12 | 11 inches | |
Göteborg medium design 1631 | 138 | 106 | 33 | 15 | 14 inches | |
Göteborg large design 1631 | 168 | 130 | 40 | 16 1/2 | 15 inches |
4. The hog on top of the keel is primarily there to allow the hollow garboard. It allows the use of straight floor timbers without chocks under them, and is a solution seen in other Dutch ships of the period. It also adds stiffness, but it s not an afterthought, it is part of the basic structural design.
6. The stem is made of multiple pieces, but not is a way that suggests it was extended, only that several pieces were needed to make up the full curvature from the available timber. If the uppermost piece is removed, the resulting stem has too little overall curvature and would have to be set at a higher angle to be able to get a bow that is not a shallow dish.
Waldemar's reconstruction above shows pretty clearly that the basic design before widening is not a good one.
