Thanks Bob!
You are using the same process for edge bending that I now use whenever I can. I mark out the hull, plane, file and/or sand them to the necessary taper of their breadth then soak them. Once in the jig which is basically the same as yours, I hit it with a hot air gun. I can usually do 5 or 6 planks a day that way as the drying time with the hot gun is minutes rather than hours.
Thanks again, I appreciate your reply and the photos. (I am with you, no copper sheathing so I try to stay with British vessels launched before about 1780)
