Xebec CAZADOR Occre 1:60 scale
Bill
When and if you decide to start on your ship, post back and you can get guidance on starting a log. In the meantime, you can go to top of any page and check out FAQ. It is a great hobby.
Mel
Paul
Thanks for the suggestions. I am still a little confused. The transom has a 5mm offset as it tails towards the keel. Do you mean that this should be removed? Part of the confusion on my part may be about part # 28( below deck reinforcement). If that is removed between transom and last two frames, there will be a small gap between 1st plank and edge of deck (under deck). As far as I can tell the bulwarks(you refer to them as ply?) are sitting on the protruding edge of P/N 28 (below deck reinforcement) Did I misread the build plan?. I have attached some pics that may clarify my confusion. Hope I have not over thought this issue :D
5mm jog in transom profile.jpgbelow deck reinforcements #28.jpgCaz transom 3.jpgremoving  support will leave gap between deck and 1st plank.jpgview from keel.jpg​
Hi
Have a look at page 1 of my build. The rear has no lip, it is a smooth transition.
The supports sit directly under the deck flush to the edging ( you have to sand then to fit), not where you have them.
Look at photos DSC03060.jpg ,DSC03065.jpg,DSC03066.jpg ,DSC03074.jpg. The planking just follows directly underneath the balwalks.
If you look at DSC03090.jpg,91,94 it looks a little like yours but that's because the outer planing coves the thickness of the balwalk and there are no planks below.
The balwalks should curve hard against the rear bulkhead.
re check. There is no supports under the balwalks at the rear.
I will do so. I have to admit that I have been inundated over the years with many negative comments about most plank-on-bulkhead kits, but I love them! I am thoroughly enjoying watching your model come along, and love reading about how others overcome problems. I have concluded that these models are as good as the builder. You are doing a fantastic job!
Bill
Thanks Paul for your patience.
I finally understand your input and will start working on corrections. My brain just would not accept that Occre would leave a transom frame that would require that much re shaping (and not mention it in the instructions). I had big issues with BENJAMIN LATHAMs stern and eventually just built my way so I guess I should not be surprised. Is this small "gotcha" common in these type of kits? Thank goodness I followed your build.
Hi Sideliner.
All kits and manufacturers have learning humps and areas that need improving in relation to instructions. All the Newer kits tend to have far better doco, but still miss the plot sometimes. Some assume you have built before ( intermediate - advanced kits) and know how to do things. I've yet to find a kit that details planking...
The Chinese kits pre cut the planks to shape/ The others you have to. Some double plank, some single.
This is what build log forums are all about. We all learn and love to share. Were not machines, we all do things differently.
Glad I could assist
Paul.
Good Day to All
I continue my build at a much slower pace due in part to holiday(Thanksgiving) but mostly because I am taking so long to shape each hull plank. Basically hand sanding each plank to indicated widths. I have tried marking and cutting with blade but find it tedious and dangerous.
You may note from pics that I finally grasped the kits intent and reshaped the stern frame while removing the previously attached lining from the back side of stern frame. I will continue hull planking half way to keel then attach garboard plank. I have scored a small rabbit along the keel to facilitate this plank.
Hi sideliner
Great recovery, love the way a wood kit can be corrected, Your'e doing a super job. The planking looks good, take time and enjoy it.
Paul
Thanks Paul
I have been complaining to myself about how long I was taking to sand down each plank. Finally woke up and put my mini plane to work. Only takes a minute or two to shape each plank and gives a much more uniform surface.
IMG_0090[1].jpg​
Hello and a Happy New Year
Lest any followers think I have snoozed off during the holidays, here is my progress on the planking. On the starboard side I planked half way up from gunnel, installed the garboard plank and worked my way down to the middle. Not sure this was such a good idea. I had to use two correction planks and three or four half stealer planks. Not a big deal, but I though that all my careful measuring and sizing of planks would prevent this issue. Not so. Since I started planking, I have read that it is not a good idea to reduce any plank by more than 50%. Also I am working my way from gunnel to garboard plank on port. We will see what we will see :? I hope I am not over posting on planking. I seem to notice that few logs show planking progress. Any critique appreciated.
IMG_0092[1] halfandhalf.jpgIMG_0094[1]working starboard from garboad plank.jpgIMG_0096[1]finish sarbd.jpgIMG_0097[1]moving up port side.jpgIMG_0098[1]trying different method portside.jpg​
Finally back after battle with flu.
Applying second hull lining with sapelli planks. I am somewhat less than expert with contact glue, but have worked out method to keep most on the wood and not on me. A thin layer on hull and likewise on plank, a short wait(seconds) and then apply plank. Glue has strong grip requiring correct placement on first try. Difficult to scoot around. I found that applying adhesive to plank "only" allows more latitude in placement, but does not adhere as quickly. As I move to port side hope to improve skill.
It has been a while since my last update. Starting to make progress and spending real time on the build. It is too hot for outside activity(99.5 deg F on my patio). I really like this kit and have only a few irritations. Primarily assembling the various gratings and forming to odd shapes. There must be an easier way. I did discover a better adhesive. It is Titebond Translucent Wood Glue. It sets fast which is useful when mounting on vertical surfaces and any missed glue lines disappear. As you can see I did a really terrible job on bow gratings. I tried making templates of grating from drawing, but due to another screw up, I did not get the bow spirit installed proportionately. Oh well it is still a fun build. Thanks to Brian077 for suggestion about pre building one cannon to check port height. I had to open a few ports. Also as referenced in other build the girder size called out in inst. is wrong. I measured height of each one and still had to grind down a few for cap rail fit.
IMG_0116.JPGIMG_0115.JPGIMG_0116.JPGIMG_0117.JPGIMG_0118.JPGIMG_0119.JPGIMG_0120.JPGIMG_0124.JPGIMG_0125.JPGIMG_0126.JPG
Great work, coming along well.
Yep the cannons are a pain. I had the one sunder the back floor that were out. Had to prop then slightly. The rest should be easy. I used a side cutter, No 11 & sander to cut & shape the gratings. Paint the gratings with some diluted PVA to bond them before you cut and they do not spit as much. I also made paper templates for each hole and used that as a guide to cut.
It is a fun kit and looks great when comleted.
1. Attached rubbing strakes, not necessarily where plans called for..just what looked right .
2&3. Hatch covers per plan.
4. cat davit assy. Just guessed at angle for cut.
5. Pump assy and bell tower. Painter pumps red
6. Red canon port doors. Might redo color. Not sure it looks good.
7Assembled oars and bundled to deck.
8.Making fuse holes for canons. Waste of time as they don't show up when painted
9. Canon assy. Very tedious for me. Covered boo boos with paint.
10. Mounting canons to deck using glue to position cordage and hold canons to deck. Another tedious task. Finally figured out how to drill holes in stanchions
and glue in shorted eye bolts. IMG_0129[2].jpgIMG_0130[1].jpgIMG_0131[1].jpgIMG_0134[1].jpgIMG_0136[1].jpgIMG_0137[1].jpgIMG_0144[2].jpgIMG_0145[1].jpgIMG_0146[1].jpgIMG_0148[1].jpg
Your xebec is looking realy good - good work.
I would like to see more often the progress - thanks for sharing with us
Time for an update. The small boat build has slowed me down quite a bit. It is not complicated, just small and easy to break. As previously noted the pictures furnished with kit leave several issues to builder interpretation. Thanks again to PaulV1958,s log for setting me straight. I am getting mentally prepared for adding standing rigging. Waiting on a shipment of new line as I don't much like the fluffy stuff in the kit. See you on deck.
Hello Sideliner,
Just found your log. Looks great - certainly a beautiful looking kit as well. Just grabbed my chair.
Regards,
Great work. You can get rid of the fluff if you wax the rigging ( which I recommend anyway), A natural Beeswax block can be purchased at most hardware stores.
