Well Ted the smallest blocks I used were 4.5mm. Personally, I loathe anything smaller than that. I have used 2.5mm for canon rigging on my Vasa.
All the single blocks were 4.5mm. The few double blocks I used were 5mm.Pardon me Dan,
What I meant is what size did you use for the larger blocks?
Ted
Hi TedCan someone tell me what size blocks the used.
There is already a lot of information on the --> Bluenose Main support Page <--Hi Ted
I cannot speak for Bluenose in particular, but all the block sizes and where they were used along with respective line sizes for the various size blocks are listed in Chappelle's The American Fishing Schooners pages 345-347 for Columbia which was similar in size to Bluenose. The block shell sizes ranged from about 6 inches to 14 inches and were internally stropped. Please feel free to PM me if you need a bit more information.
Not only too specific for Ted... I also reduced the number of various diameter blocks to the three you mentioned.I think it's too specific for Ted. So I recommend only blocks of 3mm/1,2", 4mm/1.6" and 5mm/2".
A very valuable information can be found hereThere is already a lot of information on the --> Bluenose Main support Page <--
In that chapter I made this post with a excel file with all the rope and block sizes --> Rigging and Block Measurements by Jenson, Lankford and Chapelle <--
If you wil use it, also read the post #13 for some adjustments in the file. I have related the original sizes to 1:64 and 1:72, im mm and inch.
I think it's to specific for Ted. So I recommend only blocks of 3mm/1,2", 4mm/1.6" and 5mm/2". If 3mm is too small, then go for only 4mm and 5mm.
Regards, Pete
Thank you for your response.Hi Ted
If I'm not mistaken, I believe the original kit provided blocks (single sheeve) part number C099 were 4.5mm blocks.Thank you for your response.
I'm going to go with the dimensions provided by Daniel. I'm keeping it simple using only three sizes.
Best regards
Ted
It might be helpful for you to mark all the block and rope sizes you intend to use on the YQ-drawings. At least, that helped me through a lot of issues, amongst others not ordering too much or too few blocks or the wrong size of blocks and ropes.Thank you for your response.
Best regards
Ted
I never bothered with the kit-supplied blocks or ropes. Didn't meet my quality standards.The provided blocks require work above my abilities.
Hi TedThe provided blocks require work above my abilities.
