- Oct 1, 2023
I used the same configuration. At minimums it's robust.Rather than cutting holes in the deck I added pins to the bottom of the main mast piece P15. I believe this will secure it enough when installed.
Best regards
Ted View attachment 468783
I would try to crimp the chainplate around the nail using needle nose pliers. As Dockattner stated if you anneal the brass it will be much easier to shape and drill through.Here a photo with the chain plate in place.
Best regards
Ted View attachment 469335View attachment 469336View attachment 469337View attachment 469338
Thank you, I'll try annealing.I would try to crimp the chainplate around the nail using needle nose pliers. As Dockattner stated if you anneal the brass it will be much easier to shape and drill through.
The annealing really helpedThank you, I'll try annealing.
Best regards
Ted
Hi Ted. You can mark the place of the hole on the dry-fitted chainplates with a needle. Just a little pressure is enough. With some light from beside for sure you will see the mark in the brass.I marked the chainplates with a lack marker and scratched a line for the elevation of the bolt holes. Unfortunately when I pulled the chainplates out to punch the locations for drilling the tightness of the rails scraped off the marked area leaving it blank.
Back to the drawing board.
Best regards
Ted View attachment 469437View attachment 469438View attachment 469439
