That's really impressive but above my capabilities.Can't help you their Ted, I handmade mine a little differently. I did hand make dozens of eyelets by hand with wire, all I can say is use what will please your own eye unless you want to research each actual eye type and scale it down mathematically then hand make it.
Not off the top of my head but I'm sure its discussed somewhere. Probably the best reference would be Peter Voogt.Are you aware of anyone else mentioning the size of the eyebolts in their build logs.
Model Expo sells some nice eyebolts that may be good for your application.Not off the top of my head but I'm sure its discussed somewhere. Probably the best reference would be Peter Voogt.
Thank you I'll look them upModel Expo sells some nice eyebolts that may be good for your application.
Hi Ted. At first: the entrance to the forecastle is standing in the wrong direction. In your situation, if the entrance is open, all the overflowing water from the bow will flow in. The entrance must point to the rear. See the P.10 on the main drawing on the plan 8-3.I preinstalled the bowsprit. The wood block glued to the end worked wonderfully.View attachment 467021
When not handmade I sometimes used the 2mm eyebolts from Amati, partnr. 4704.Not off the top of my head but I'm sure its discussed somewhere. Probably the best reference would be Peter Voogt.
Thank you PeterHi Ted. At first: the entrance to the forecastle is standing in the wrong direction. In your situation, if the entrance is open, all the overflowing water from the bow will flow in. The entrance must point to the rear. See the P.10 on the main drawing on the plan 8-3.
4704 is brass
4703 is copper
I unraveled the thread and reseized using a single strand.
Best regards
Ted View attachment 467620View attachment 467621
Hi Ted
Considering the era and type of vessel shouldn't the anchors be iron stock anchors or maybe bank anchors?
Hi Ted
Hi Allan. I was just reading your post in Ted's build-log. Then I saw the post of Johan (with a mail alert in my inbox.). I hope that Ted will find it ok for answering. It's a kind of special stuff for the schooners.If I remember correctly, @Peter Voogt posted some useful information with regards to the Bluenose anchors.
Thanks Peter, I was just too lazy to wade through 100+ pages of your (BTW excellent and must-read) blog...Hi Allan. I was just reading your post in Ted's build-log. Then I saw the post of Johan (with a mail alert in my inbox.). I hope that Ted will find it ok for answering. It's a kind of special stuff for the schooners.
During my build of my BN I made this post: --> Banks and Harbor <--
The YQ kit is only provided with the anchors Ted is showing. We had the luck that our fellow member Dean @Dean62 designed a Club anchor. And after mailing his file we had a friend her in the Netherland who printed a few of them. So a few builders of the YQ-BN have both type of anchors on there BN.
The excel index I once created for my build log pays off from time to time.......Thanks Peter, I was just too lazy to wade through 100+ pages of your (BTW excellent and must-read) blog...
We know those drawings. We (Dean) designed the stock (harbor) anchor partly based on these drawings. For scratch build there are often better options, but most of us have to deal with the items of a kit.Not sure if one of these, or neither, are appropriate. They are from Chappelle's book on fishing schooners. The dimension may be different for different size vessels.
Bank anchor
Iron stock anchor
