Thanks @Warlight. It appears that is so. But I'm not sure how to bend them in that direction. especially given they are laminated pieces. I'm guessing ZHL realised the problem and corrected it in later versions. Maybe I should try to make my own.
**VIEW THREAD HERE** |
Thanks MystRacing. These parts would be long enough to bend but as you say actually doing that would be problematic. The model does not have any other pieces that are remotely like what needs to go on the bow of the ship. I may contact Max as you suggested. If he was willing to send updated pieces for a minimum 7 year old model he would be the best proprietor I ever worked withYou could try e-mailing Max at ZHL. He's been really accommodating to others maybe he would send you some updated ones. It's hard to believe they would actually want you to do a radical bend across the grain with the way the parts are cut. I was wondering if they are long enough even if you could bend them? If not I'd look around and see if there aren't some shorter arched pieces that don't seem to go anywhere else that might make make up the bent end of the part. Maybe they just don't show on the plans. Or as you say, you could just cut some based on your plans.
1+2) I guess there should be two double blocks fixed at the mast - for each side you will have a separate blockCan someone answer the following for me please.
1) for the red circle below does this mean one rope from each side of the spar wraps around the mast and the other goes through a block?
2) should there be one block (ropes from each side of the spar go to one block) or two blocks (each side goes to its own block) here?
3) For the blue circles where do these ropes go? do they go down to the baling pins near the deck? If so do I just choose any pin that seems right?
4) what size thread is used for this rigging? The kit has 1mm and 0.5mm
Thanks Jimmy that makes sense. As it is a fantasy ship as you say that might be why the plans don't specify particular pins. The plans specify the thread for the shrouds and ratlines but that as it. that's why I wasn't sure.My opinion (for what it's worth!)
I would think the rope starts fixed to the mizzen mast, then goes to the block on the yard, back through a single block on the mizzen mast and down to a belay at the mizzen foot.
Two single blocks, one each side.
yes, down to a pin on the pin racks. Since this is a fantasy ship, you can do whatever you want, there is no 'correct' or 'wrong' pin.
I would guess the smaller size for the running rigging, the larger for shrouds, stays etc.
Thanks Vfordyce. Could I just use thread. is there a reason to use wire?Ditto what @jimmystratos said. You probably will have to strop the block using wire to attach to the mast. You use thin wire to go around the block and then bend the end to a loop. Many suggest to blacken the wire first. My first attempt was not that pretty. I later bought some specialized needle nosed pliers to tighten up the loop a bit.
That would be great Jay. if it doesn't work out though I should be OKInteresting solution to fit the trees on the masts. When I was doing mine I thought how the heck are you supposed to do this and I wasn't sure I had the right parts to do it with. I will try to take a picture of my rigging plans for you to see where the rigging attaches to the belaying pins. It is rather hard for me to see the numbers so it might not translate very well in picture form.
Apparently there are different types of stropping for different purposes. When a hook or a loop is called for, I’ve used wire. I’m sure more seaworthy lads could explicate the variety of uses for stropping better than I. Now if you ask me the difference between an elevator and an elevon on an aircraft....Thanks Vfordyce. Could I just use thread. is there a reason to use wire?
