If I may give a couple of simple suggestions for better pictures. It appears that the main problem is camera shake during exposure. Cell phones are notorious for this due the way one has to press the shutter button on the screen. A couple of tips to help:my pictures suck, I'm going to take a better picture of the garbour plank if I can. View attachment 290244
Hi Rick if this was a single plank ship you would need to cut a rabbet in the keel ( a angled slot for the planks to fit into ) with a double plank kit it's not really necessary. On my BP the bottom planks finished at the bearding line and sanded flush to the keel.
Another suggestion that works for my phone. When taking closeups of small items my phone often won't get a good focus. I've found that if I move away a foot or two then zoom in it looks better. Also helps with the lighting-less shadow because I'm not blocking the light as much.If I may give a couple of simple suggestions for better pictures. It appears that the main problem is camera shake during exposure. Cell phones are notorious for this due the way one has to press the shutter button on the screen. A couple of tips to help:
1. Use more light on the subject. More light increases the camera's shutter speed so that shake is not so evident.
2. Brace yourself against something to help keep the camera steady. Something like putting your elbows on a table surface (or held against your body) instead held out away from your body.
Mine's in my loft.If my work shop looks weird that's because it's in my living room of my apartment. A lot of yours blow me away with all your tools and machines.
You’ll just have to experiment like we all do till you get the look you want. I usually just use polyurethane to enhance the natural color. I sand off any glue before staining or using poly. But if you use CA or super glue, it sometimes soaked into the wood. On this latest ship, I coated it with a thin coat of colored putty that was close in color to my wood. It filled in any cracks and the little holes I had drilled to simulate treenails. I sanded again and applied the finish. I was pleased with the results. There is no real right way. Experiment! See what you like! It’s always builder’s choice, anyway. I learn by doing. You’re doing fine. Enjoy the experience.I was using a lot of different stains the beach wood i stained from natural the black walnut came with the kit it just needed something to look brighter, using the beach on the deck black walnut on the hull. Any comments? Wanted the deck color to be like a gold color like I seen on someone's log it looked really nice after the varathane. It was very hard to match. I ended up with colonial maple, any suggestions. View attachment 291884
