To be honest, once the wooden walkway is added above the guns and the two boats are added, you won't see much of the guns anyway. Overall, you're doing great on a challenging model.
I appreciate that, thank you. I agree with you on that. I am however taking this opportunity to better myself as I want to do the Caldercraft Victory next. After the two and a half hours it took me to get one cannon done, I figure I am in need of much practice.To be honest, once the wooden walkway is added above the guns and the two boats are added, you won't see much of the guns anyway. Overall, you're doing great on a challenging model.
If you have springy hobby forceps, you place those upside down in a set of "helping hands", and hold the block in the forceps, then stiffen the end of the thread with CA glue, then cut the end of that stiff thread at a 30 degree angle so it's really pointy, put on your magnifying headset so you can see better, THEN attempt to either tie a strop around the block or thread it through. I am getting used to making gun tackles with 1.5mm blocks! You really have to have steady hands, also, and LOTS of patience. I usually listen to music or new talk shows on YouTube while I work. Since my model has 102 guns, I REALLY have to remind myself that the tiny detail rigging will come to an end someday.I made some smaller hooks out of 28 gauge wire. Shortened my seizings and used 2.5 mm blocks and it looks much better. That 1mm difference in blocks led to much more cursing, but I think it is the solution. I am having trouble threading these tiny blocks, even with needle threaders. Any suggestions?
Yes, I am looking at the work load ahead and it’s going to be a lengthy process rigging these cannons. I have to keep telling myself to take my time and do each one correctly because of the wow factor at the end. This site and its members helps push me in the direction of quality rather than quantity and it’s definitely paying off.If you have springy hobby forceps, you place those upside down in a set of "helping hands", and hold the block in the forceps, then stiffen the end of the thread with CA glue, then cut the end of that stiff thread at a 30 degree angle so it's really pointy, put on your magnifying headset so you can see better, THEN attempt to either tie a strop around the block or thread it through. I am getting used to making gun tackles with 1.5mm blocks! You really have to have steady hands, also, and LOTS of patience. I usually listen to music or new talk shows on YouTube while I work. Since my model has 102 guns, I REALLY have to remind myself that the tiny detail rigging will come to an end someday.Whatever you do to add detail, it will slow your overall progress speed, but the result at the end is VERY impressive. So, take your time doing the details. That's what makes your model seem impossible to those who don't build models like this.
Out of the frying pan and into the fire! I'm going the other way. I'm doing boats now: the Galilee Boat, otherwise known as the Jesus Boat.I appreciate that, thank you. I agree with you on that. I am however taking this opportunity to better myself as I want to do the Caldercraft Victory next. After the two and a half hours it took me to get one cannon done, I figure I am in need of much practice.
Either that or use thinner thread. I always use the ca trick too.If you have springy hobby forceps, you place those upside down in a set of "helping hands", and hold the block in the forceps, then stiffen the end of the thread with CA glue, then cut the end of that stiff thread at a 30 degree angle so it's really pointy, put on your magnifying headset so you can see better, THEN attempt to either tie a strop around the block or thread it through. I am getting used to making gun tackles with 1.5mm blocks! You really have to have steady hands, also, and LOTS of patience. I usually listen to music or new talk shows on YouTube while I work. Since my model has 102 guns, I REALLY have to remind myself that the tiny detail rigging will come to an end someday.Whatever you do to add detail, it will slow your overall progress speed, but the result at the end is VERY impressive. So, take your time doing the details. That's what makes your model seem impossible to those who don't build models like this.
DittoThis attitude will result in a fantastic model! Bravo!
I tried to take a video but it was too big to post. I’ll see if I can find a linkHow does it work?
Couldn’t find a video applicable to model ship building so I’ll try to explain the best I can.How does it work?
Carefully pull the seizing loops tight, organized, and toward the end of the tool. With a swift motion, pull the loose end off the seizing line off the tool and tight around the double looped thread
I have extensively used this great tool in my previous buildI tried to take a video but it was too big to post. I’ll see if I can find a link
It’s a must have in my opinion. It actually may have been your thread that I got the idea from!I have extensively used this great tool in my previous build
See Youtube video HERE
Good. Excellent cannons. The smaller blocks make a huge difference visually. It often the small things which make the difference (pun intendedFinally got the first row of cannons complete. I am quite happy with it and am glad I hit the rewind button and changed out to smaller blocks thanks to the suggestions of the members. I am also excited to switch gears and get some of these walkways and belaying pin racks going!
