ZHL Soleil Royal
Nice, when it come to guns rigging, on mine, I'll only do an illusion for the 3rd battery gun, the other, I won't bother because to me, they won't be visible much.
What are these style guns called? And do they get fully rigged like the other carriages?View attachment 348564
Maybe this is what they are trying to simulate?
images
That wide carriage is difficult to crew serve on the narrow confines of a ship. The closest example would be something like this:
French, 1689.
This style of carriage is overused on many kits, especially Mantua kits like San Felipe. DeAgostini's HMS Sovereign of the Seas also features this style of carriage on the uppermost decks. The carriage is more suited for land fortifications than maritime use, and it was usually found on earlier ships in the 15th century, when land carriages were first being fitted aboard ship. It is probably only used for the lighter guns on late period ships.
They are supposed to be lighter guns. I didn’t put a recoil rope on mine because they are lighter, but I had rigging to bring them up to the sides of the ship. I had a double 2.5mm block up front and a single towards the rear. I also read somewhere that the SR had bronze cannons. They were more expensive but lighter than iron ones. At least one other guy cut the tails off, added a knob where the tail was, and bought new carriages. If you’ve seen my log, you will see a lot of mistakes to avoid. A15A6720-8D92-4F80-B44A-2EAE0F4D00FD.jpeg
They are supposed to be lighter guns. I didn’t put a recoil rope on mine because they are lighter, but I had rigging to bring them up to the sides of the ship. I had a double 2.5mm block up front and a single towards the rear. I also read somewhere that the SR had bronze cannons. They were more expensive but lighter than iron ones. At least one other guy cut the tails off, added a knob where the tail was, and bought new carriages. If you’ve seen my log, you will see a lot of mistakes to avoid. View attachment 348630
I have yet to see documentation for these types of carriages used on large warships, even for the lighter guns on the upper deck. Has anyone got any research information on these?
I’ve been messing around with the cannons and doing what I can. I had to order some rigging rope and blocks to finish them out and install them. I’ve also started installing the racks that hold the deadeyes (if someone could enlighten me on the actual term I would appreciate it!) I used a contour finder to match the curve of the ship and added pins where they mate for strength. This was actually one of the easiest things to do so far on this build. I’ve been using teak oil on everything and so far I really like how it’s making the different woods look.
Your channels look good. So do your guns. French gun carriages had a hole in the sides for the recoil rope. The ropes didn't go around the round knob on the rear but through the carriage. There is also a triangular piece that goes under the rear of the gun.
Yes thank you for reassuring me on that. I am waiting on some good rope from Syren for that and also some patina to turn my brass pieces black before I install.
Did you have trouble with the kit only coming with 14 out of the 16 smaller cannons?
