Since the level of detail a person may add and the availability and amount of research a person may chose to perform will vary with each modeler, the times I show are related to the actual work performed on the vessel. Each person’s ability to read and interpret plans can vary a great detail. Thus, the time reflects only that used to measure the plans for comparison on the vessel or to determine the size of wood used to make a part that is unclear and not listed in the instructions or on the plans separately. Hopefully, by doing this, a person can use this as a guide to determine the level of commitment necessary to compete this type of project or can use it to gauge how far along they are if building the same vessel.
I have got the first planking of the Cutty Sark done so it is time to post some pictures. At this stage I have 60 construction hours and over 100 parts. The newer kits use 1.5 mm balsa strips for the first planking and the second planking is 1 mm walnut strips. The balsa makes bending easy and on a streamline vessel like this, no soaking or heating is required. I do not think this would be a good planking material for earlier vessels that are not streamlined for speed like this one. Sanding is also very fast even when using 320 grit as I did.
